How do you keep a constant font type and size?
Seems that I have to set the type and size each time?
Thanks!
Tom D
Thanks!
Tom D
Currently it is set to a default value for each message. It will also go back to the default with every new message. We will look into modifying this.
Grazie....
-TD
Why does the space bar sometimes act as enter or return? is it because too many people are typing at the same time? I like the other changes though... now just to get people out of the "default" select room! lol
We have a Chat Room????? :confused:
LE DUH!!!!!!!!
:aargh:
Very top of the web page....LIVE CHAT
Tom D
3 things so far....
Change the timeout in the Lobby.
Cursor gets "lost" when the chat frame refreshes
which can happen when you're in the middle of
typing a sentence.
You have to mouse back to the text are to continue
typing.
And you still can't change the font size ;)
Tom D
Yeah. i hate that cursor thing to. I also got a popupthing about some dating stuff. I dont like popup`s
Why not make a chat that can be used in java and mirc?
Runar.
  • Admin locked this topic
    • By Brent Wright
      Don’t wait—MotoSport’s exclusive deals on genuine OEM parts won’t last. Upgrade your ride and save big on top brands like Honda, Yamaha, and KTM.
      Shop Now
    • By Westfalia
      So I've been told that it is a waste of time to use the two piece rims with O-rings like they came originally and to just use tubes.  I have not had much luck finding the 5" O-rings anyway, so how do I go about sizing tubes for these rims? I think they are 7 or 8" wide.
    • By Joeguy
      I been working on this thing for like 2 months now and it will not run right, is very smokey, and has a pretty loud tap that i think is in the bottom end. Not sure how much the parts are but i will put the time into it if they are pretty cheap. Im not very experienced but going off how the plug looks and the oil on top of the piston i am getting a whole lot of oil coming in from somewhere, not sure if it can come from the valves or if the rings are just shot, my cheap scope cant really see the walls of the cylinder too well.
      20241009_123850.mp4
