A Simple Way To Mount Devices To Your ATV Or UTV
By Admin
By joezee13
By pastorjeep
Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
By ATVNetwork
By Admin
Looking for Arctic Cat ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Arctic Cat ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Arctic Cat ATV manufacturer, however there are plenty of aftermarket Arctic Cat ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
