Cvt durability
By BenJammin
By Gwbarm
It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
By dlw
i have a 2016 kymco uxv 700i and i am having issues with transmission. it makes a horrible noise in 2 wheel and wont move. it will move in 4 wheel but still makes noise. has anyone had this same issue?
By ericggg
Hi, all
I have a 2010 Honda try 420 at and I'm having an issue with the transmission. Every now and then the while riding the transmission goes into neutral or stays in gear high or low. Recently while riding it stayed in 4th gear, had to come to a stop and rock it back and forth and it want back to first. Did any one have similar issues and what can be the diagnosis to this problem and is it worth fixing. I called the Honda atv dealer and told them what happened and they said it's going to be $2000-$3000 to fix that seems crazy. Any help or idea will be greatly appreciated.
Thank you all
By jatho
Does anyone know what year they stopped producing the King Quad 300? - particularly in Australia and New Zealand
What were the design changes?
