pokerl0w
1993 Kawasaki Bayou 300c 4x4 Tie Rod and Shifting Issues
this bike! did this guy sucker me or what.. ok, looks like this means something is bent that I do not see or one rod is longer vs the other?
how long do you think this would last before it ripped into the tire? this is the right side, left side tire clears no problem
20190118_182000.thumb.jpg.f316167ced1027cc6af8a8ac62473a90.jpg20190118_182019.thumb.jpg.d5625d228dbea3e587f670596362a5be.jpg20190118_182025.thumb.jpg.6cef4b5bab8ede330271a0f980360985.jpg
I can not find them on www.kawasakipartshouse.com
Share this post
Link to post
perhaps this is not the rod, looks like the piece it connects to. I need to pull the wheel. this thing is missing pins and such 😕 heh well, look at all my improvements I'll have in no time! 💪
Share this post
Link to post
That part you think is bent is not really likely to bent.  It’s more likely to snap or break i should say since it’s a casted metal piece.  I would def pull the wheel to see if something is  missing like a spacer or a blown/collapsed bearing or the wrong rim maybe?
Share this post
Link to post
1 hour ago, JacobSlabach said:
yea some folks are like that... just out to scam people..  I got screwed on the bayou 300 I bought too.
i don't mind someone painting over a dent or using non-oem screws and parts, etc. but this guy said he rebuilt things - I bet he bought a chinese carb, new tires and that's it. claims he bought it from auction. I can not find any vin 😕 heh yeah.. well I'm learning tons, which is fun since it's not forced schoolwork heh
I'm hoping wrong rim. You are right, that steering knuckle is thick metal and lined by 2 bolts, I do not think that can be adjusted. Must be wrong rims or tires (probably both).
Share this post
Link to post
tire off..
about to switch left/right to see if I see any difference. right now, I can't tell other than that rod end looks like it should be replaced and if you want to clean and keep rust off cast metal, rub a tire on it for about 2-3 hours
while I'm rotating, can anyone tell me more about this steering knuckle/plate setup (again this is right front wheel)?:
20190119_122036.thumb.jpg.999860924e3f5896c0603be4a545bc16.jpg20190119_122051.thumb.jpg.3e97eeb6e80dbd36ede98fd8ddd6f2cb.jpg20190119_122105.thumb.jpg.01eff69c0e4f34a917feb2ec1f208209.jpg20190119_122121.thumb.jpg.9807d645e973742d377a2d025426d12b.jpg20190119_122226.thumb.jpg.60a105f81a7951974d7caf535fd47ea6.jpg
Edited by pokerl0w
forgot polite words
Share this post
Link to post
Does there look like any welding was done on any of the parts ?
You are going to have to turn the wheel in both directions. And while doing so take a few seconds and try to wiggle the parts on that front end for movement. Also look behind the rotor and compare one rotor to the other sidde. Also clearance between the back plate. Compare both sides take some pics and post.  Maybe we will see something that stands out.
Share this post
Link to post
yeah I def see differences. looks like different hubs. I have not measured the mounting bolts
20190119_143537.thumb.jpg.2d11a7bb2eddc191acf45e4be4bbc52f.jpg20190119_143546.thumb.jpg.23338df6d218ec4fd5ec5af09673b70a.jpg
Share this post
Link to post
yes perhaps it is not the color/nut there, but the compression of the hub. I recall doing something like this with brakes/calipers.
I measured and left side appears to be compressed in a bit more.. might take photos and upload to confirm what I am seeing.
Share this post
Link to post
 this steering knuckle is not the same as the other. I would think they should be same height. The right is about 1/4" or so taller and further back.
I do not have an image with tape, here's best I have right now without correct angles.. when I measured, however, that is 1 thing. Another is the distance from the rotor to end of wheel bolt is also about 1/8" or maybe 3/16 difference between the two. i do not see how compression could play into those measurements. it's all metal 😕 I need a either a larger right wheel n tire that'd look sweet heh or I have to find a correct right buckle which most seem to sell as complete  housing
left side:
right (rubbing) side:
Share this post
Link to post
15 minutes ago, pokerl0w said:
... I need a either a larger right wheel n tire that'd look sweet heh or I have to find a correct right buckle which most seem to sell as complete  housing
giphy-tumblr.gif?cid=6104955e5c43da77614
Share this post
Link to post
So most likely it was wrecked and another year knuckle was put on you think ?
You can’t do a larger  front wheel.   They all have to be the same size or you will destroy the transmission.
Edited by Frank Angerano
Share this post
Link to post
well now I'm confused. ebay shows me left/right knuckles and they appear to be different shapes/sizes.
I can not see it on partzilla/others (yet). still searching.
and yea wrecked/salvaged bike I'm thinking.. with the damage being mostly on that side (it seems) and maybe he did not know the year and bought 95 and it's 93? (I'm assuming it as well). although I thought those years almost everything was identical for the  bayou 300 4x4.
Share this post
Link to post
in terms of damage. there is damage in various places. I would think the right side has something but I have not spotted a bend in the actual frame on that front/right side. however, if there is - it should be helping in this situation? or not at all. I have to figure out the wheel size or try my luck with other parts as I can not seem to order just the knuckle and gl with size specs from ebay parts.
here's some more photos if you see anything. my best guess is I bought a salvaged unit. the guy chopped the vin and welded in where it used to be (or maybe the person before, who knows). they guy I got from claims he bought off auction and flips toys. this stated as to give some perspective to my struggle in finding details that can help us.
20190119_204858.thumb.jpg.9c064aa678f86ae6827d9e566e5190ab.jpg20190119_204908.thumb.jpg.db90b36986a00b8bcb240012c17c57bb.jpg20190119_204938.thumb.jpg.2514a99240a026a9ed448f22ed100349.jpg20190119_204954.thumb.jpg.7a19b282bfbc339ad434b1183a2c4608.jpg20190119_205655.thumb.jpg.9962e0277f6f9fe4d148f3c8bbf2acae.jpg20190119_205711.thumb.jpg.d97fd56f0a34577858c355e74accda1b.jpg
there's no snow on my yard, I am bummed.  I can not sticker this and take to a trail and play (legally anyway) where there is snow. either I buy one that I can register and get a "green sticker" .. or I buy a frame and swap everything. I really feel like doing so as then I have zero question as to what I am working with. assuming the engine can mount into a range of years, which, I would get a 1994 frame based on my research and parts available.
I read it takes a pro shop about 1.5 days to complete the job of swapping frames (bent frame and minor bolt on part damage also replaced). front and rear look pretty easy.. the center is where I fear I'll get lost in weeks of trouble.
Share this post
Link to post
be cool if each part had a no. on it to reference 👍
well... either I buy 2 larger front wheels n tires.. and that is $220 at least
or a new used right side and hope it's the correct size, no way to know based on 2d photos
https://www.ebay.com/itm/371492357629 <- this looks almost larger than what I have now. and seems expensive to me 😕 no returns, bah
this should be new? very expensive but have return option:
Edited by pokerl0w
Share this post
Link to post
if so, very little and it would have to be on both wheels the same I think as I tried the other tire (left) and same result. seems unlikely both wheels would have same bends 😕, right?
however ... axle. hmm how do I test (I'll have to start searching).
I think the brake or something is rubbing on the rotor, that's about all the sound there is when rotating manually. and they do spin
Share this post
Link to post
  • Similar Topics
    • By Outkast7222
      Well been lurking for a couple years, figured its time to say hey! Been riding in MN since the early 80's been on just about anything and everything with a motor. If you are from the area hit me up! Currently riding a 2018 Sportsman XP 1000, but thinking of going to a General or possibly a Maverick Trail.
    • By Gilbey
      Does everyone run the tire pressure as stated on tires or perhaps a couple # below to soften the ride a little?
    • By raybob
      are the side by sides that rural king sell any good they look good
    • By Cody Smith
      Does anyone know the exact name of this part? Bottom of tire is tilting in Under the bike and top or tire is tilting out away from the bike. Not terrible but it’s a little 90 for kids want to make it safe. Just need to know exactly what the part is called.
    • By Buell
      I have a 05 sportsman 700 carb and I also have tires and rims from an 19 Polaris General. Bolt pattern is the same. Do I need to change out the studs to be bigger?
  • Similar Tagged Content
    • By Bryson Bailey
      Hey I have a Kawasaki buyou I put a new carburetor on it and a brand new spark plug coil and still firing up could you know what my problem is anyone please
    • By 1911Neil
      I had a quad fall in my lap a couple weeks ago. The only things I knew about it was it was a Kawasaki Bayou 220, was in pretty rough shape and was free. I couldn't say no to a fun little project. I've been looking a different ATV forums gathering quite a bit of info and decided this was the one I wanted to join.
      Thanks to this forum, I found the VIN under about an inch of mud and cross referenced it to be a '98. It had been sitting outside for at least 5 years and was told it ran when parked, but had no brakes. Squirrels or mice had been chewing on the handlebar controls and it's generally just kind of beat up.
      So far, I've gone through the carb (not near as bad as I expected), freed up the brakes (will probably need new cables), replaced the spark plug, air filter, petcock and put a new battery in it.
      The gas tank had been empty and looked clean so I put some fresh gas in it and tried to crank it today. I got a neutral light, but the starter button did nothing. I tried pull-starting it and it wouldn't fire. I checked the plug and wasn't getting a spark. I started digging and found some potential issues and some definite problems.
      I have a wiring diagram I found on here but it's just a picture or scan out of a book and hard to read. I don't see a reference to a black/yellow wire, which is my first problem.
      First, it that a factory crimp? One of those wired looks like it goes to the connector in the 2nd pic. Is that just a spade lug type connector? I pulled on it with some needle nose pliers but it didn't seem to want to come off. In the 3rd pic, should there be a fourth wire?
      I've read through and bookmarked the threads Andrew Baker and Arizona have going but I figured I needed to start with these obvious issues first. I have lots of pictures, so if there is something else you want to see, just ask. If I don't already have a pic, I'll take one.
    • By Mike Strayhorn
      last year I bought led lights when I was riding my 4 wheeler the lights started getting dim shut off
      now my 4 wheeler will not start the battery is hot everything is dead I checked the fuse and its good
      would there be another fuse I am missing I'm took the led bulbs out and replaced them with the ones that was in there
      wonder what meh problem is
    • By EoNe Frost Vortex
      Hello i was wondering if someone could help me out iv recently got a Kawasaki klf 220 it needed big end bearing changing so i rebuilt the engine and the bike has compression starts first time every time but after i have been riding for about 10 minutes oil starts to leak from the head just below the exhaust so i replaced the gasket still done it so i took it to a shop he done the same and it is still doing it any information would be great thank you
