7 minutes ago, JacobSlabach said:
@pokerl0w you could buy my sportsman.... has snow tires on it already lol jk
I feel like Seinfield or Leno.. without their financial abilities just their motor desires! I still think I'm putting up a 2-story garage with lifts and the works. Wife thinks I'm crazy and in reality if I get a 10x20 shed up, the town will celebrate heh.
Because I want them all!
Yes your sportsman! If nothing else just to have another toy to play with and swap tires around. Maybe I'll build 3 10x20s and nobody will call me out for permits :P
  • Haha 1
I wish I was able to do this. I can't even put a brick down without a placement permit. Hell, I can't even put a nail in my wall without them having to know. This village sucks. Lol.
Ultimately. I'd love a 10x20 2 story
Dam @pokerl0w that’s a lot of snow. I’ve been watching the news and and seeing some posts/pics on social media about the snow out there.  With the right machine it could be a lot of fun! Even with all my sh** I have to ride I would prob just stay in and eat and drink 🍺.
if I read the building code correctly (and I have not done real construction since post-highschool) in most california counties, you can build a non-electric/plumbed detached building under 120sq ft. without anyone else's opinion in the matter... Of course many counties (especially SF/SValley) use that as the state minimum and make it near impossible to build, as you say, without a permit for color, shape and dangle angle heh
but to be most clear, my 10x20 would be single story ... or was, until you gave me a great idea!! I could go basement too maybe.. 3 story 10by coming up :D  basement almost never counts to the sqft out here unless it's "finished, with plumbing and window for escape" and the 2nd story might have to be shelving or clear with joists for pulleys (my wife is going to have many more opinions)
where's Tim the tool man (Home Improvement) when I need him! ah ah ah
lmao it started out a great fun... until I got the QX56 (suv, 4 wheel drive, + mud n snow tires) stuck in about 4feet even had cables on! that car was stuck for 4 days. between work, sick (we also caught the flu for the first time in my life since toddler) and trying to get some sled time in with kids... I was shoveling like it was a work out for 4 damn days. Not too mention ice melt and all that. Between my atv oil leaks/spills, the ice melt (antifreeze) and all .. I have more chemicals in my yard the neighbors will call us The Oblongs come spring heh
I finally had to have wife punch it, and pull it with a tow strap - after the 4days of shoveling! Now we are getting crazy rain, melting the snow - mocking my efforts and, hopefully, diluting the chemicals as to not morph and critters to zombies.
  • Haha 1
    • By BillR94
    • By BillR94
      Thank you for your time
      Bill
    • By wjmedic
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By gohndd
      Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
