2001 Kawasaki 300 bayou shifter shaft
By bob2007
By justent_88
By Johnfj44
The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
By cavry
Thanks for any help
Cavry
By HSTAR
