OK ya'll.I need your help again.My ATV, 2004 Yam Kodiak 400 4x4,needs a new REAR rim or wheel what have you,whatever term you prefer. I've posted pics here as you can see.The tire is a 25x10.00x12 . As you can see its a deep REAR rim.I cannot seem to find a deep REAR rim. (Capitalization for emphasis) . The only sizes I can find listed are for both the front and rear wheels which is  12x7  4/110.  This doesn't help me much. So,who can help me out? Im getting desperate now!LOL!
you might consider something like this and then if its not spaced in enough, throw some spacers on it and it should work...
depending on the bike's condition, I would go aftermarket on the tires and rims and throw a lift on the bike make it look sick..  maybe not the lift lol but you could really improve the quality and look with aftermarket rims and tires..
sorry when I said 'this', I meant this link https://www.motosport.com/product/?adpos=1o3&cc=us&creative=291553397478&device=c&gclid=Cj0KCQjw1pblBRDSARIsACfUG12lZFenXx-prWsjOvJzbjcvkXnXLv7JWorwwkhOuYZS6GQop71rlxAaAtpBEALw_wcB&key=ITP-Delta-Steel-Wheel&matchtype=&mrkgadid=3309195370&mrkgcl=500&network=g&product_id=ITP000D-X001-Y001&pssource=true&rkg_id=0&segment=badger
  • Thanks 1
    • By quadnut20
      Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into  ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
    • By jannonballs
      2001 Yamaha Kodiak. Rebuilt and cleaned carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
      IMG_4791.mov
    • By Mudseeker149
      Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
    • By sunn
      Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
