I have a 2018 450 and the digital gause has started flashing on an off while driving. The backlit also goes on and off. It is worse when I hit the gas. The battery died a few weeks ago and I jumped it but its been fine until last night. Called the dealer and showed them a vid and they recommend replacing the gauge and its like 600 bucks. The machine has less than 100 hours on it. I would really hate to have to change it out. also the unit sometimes has trouble starting. Any ideas?
Did the entire gauge start flashing? Can you post that video? If the entire gauge was flashing like when you turn your ignition on or off, there's probably an electrical issue.
  • 6 months later...
    • By HoldenBoy
    • By tds7
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
