By bob2007
By justent_88
By Roofus
I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
[removed broken image]
By cavry
Thanks for any help
Cavry
By HSTAR
