Have you checked the needle on the throttle slide to see what clip it’s on? I would  try to move the clip down one or two spots closer to the bottom.
And when the engine is running if you can turn the air /fuel screw all the way in the engine should shut down. If not then that screw is worn and needs replacement. The engine should immediately respond to any adjustments on that screw.
If not then it’s def going to need a new jet kit.  I was looking on eBay and Amazon. It has to be an oem or better brand. It was $27 bucks. It has to have the air fuel screw as well and all jets.
I would order one and take the carb completely apart and soak it in a good bath for a day or two.   Then blow every port out on that cab with some good air pressure.
Reassemble and set the air/fuel screw at 2 full turns from a snug position.
That would be my way to go about it.
I can't see the picture you tried to send. And I'm I just going to order a kit for it just to avoid all the B's, it wouldn't hurt to get it anyways. I didn't get into the carb aga n yet but I'm f it's the needle in thinking if and it has a little c clip in it there is only one spot for it to go. Not saying I looked at it real close either. I'm starting to break it back down see what else needs to be fixed and clean it up at Sam time. Here are a few pictures.
Would have have any idea where this goes it was in the box of parts and for the life of me I can't remember. I havent messed with these things since I was a kid and I didn't take it apart to be able to remember where it goes. I thought it was the chain roller but it's on there
Ok so oe will work. Any idea what that part is for I sent you a picture of? It was in the box of parts and I can't figure it out
Edited by Chris2018
Miss type
That's what it looks like but there is one on it and I asked the people and they said there wasn't any extra parts lol
Man that bike looks nice
Not going to lie deffeinetly going to steal some of your paint scheme. They painted my foot ped and sh** green I like how you're are black
Feel free to take as much of the paint scheme as you like.  I like the black because it gets the most wear and tear down there with the feet.   A bright color would show everything.
That chain was $20 bucks on eBay
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F273576057240
Edited by Frank Angerano
So I finally was able to get back out to the garage and work a little more I just replaced the top end gaskets and am a little confused about setting the timing. First the flywheel ended up moving while removing the head. All I had to do was continue the rotation and set it back at top dead center correct? And when setting the timing do you line it up with the "T" on the flywheel it is it the notch. It got me a little confused bc this is the first four-stroke I have worked on.
Thanks. And don't ask me how I completely missed that in the manual. But it was  originally lined up with just the notch befor the T. Is there a chance the velves are bent. Or is that not far enough off to cause damage
And the top part of the dot on the exhaust cam is lined up with the top of the head correct while the inlet cam bottom part of the dot is lined up with the top of the head correct?
So to make sure I'm clear as I'm getting ready to do this. My feeler gauge that says,.    .508                                                .020mm , is the correct one?
On your feeler gauge the .020 is the Inch measurement which is equal to .508 mm
Frank is correct that it is the right gauge, yet he is mistaken to say .020 is 20mm
Try to remember that 1 mm is = to .03937 inch
Its been confusing the hell out of me bc I seen someplace that they should be set at .008 also
And in the manual is says 20-24mm so when I was looking at the gauge I was thinking the .20 was in inches and not mm and I don't know just confused the hell out of me
I'm trying to make sure I got this right. The 3 degrees messes me up some. Here is two picture of the way I have the timing set. I have the 1st and 43rd tooth marked along with the dots on the cams.
That is correct @Freezeman thank you for clarifying that.  @Chris2018 that looks correct with the timing. When you have the cam chain tensioner tight rotate the engine without the spark plug installed and make sure it cycles nice and smooth. You can use your hand and slowly push the kick starter down nice and easy.  Feel for any hits or resistance  and check that the marks line up on the sprockets as you rotate the engine and the piston hits TDC again.
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By RGS
    • By Dumass
