Since  Kawasaki doesn't give the  size and pitch of the bolts, I would suggest estimating the diameter of them  and then  go to a metric bolt supplier and  buy  one bolt of each that appears the same size. Get one of each pitch if there is a fine and coarse pitch  offering in that size.
Here is a conversion chart  of common inch bolts and their standard metric equivalent. I'll add it to   the downloads section  also.
Whenever I find a bike that I buy for parts and won’t need after I’m done tearing it down I keep all the bolts. I have a sorter and try as best possible to match them up.  This bike I just finished needed bolts. I went to the bins and boom I had what I need.  Never throw metric bolts away they are like gold when your in a jam.  Especially for the plastics. Most common sizes are 8,10,12,14mm on these machines. I keep em all!!!!!!
On 9/13/2019 at 10:32 PM, Tahj said:
there are a couple of inexpensive metric thread pitch and hole gauges out there
Good tip! My bolts are bent on the bottom of my quad. I need to look into some skids.
    • By docdoug72
    • By neilroy87
    • By sugrbuzz
      Looking for a service/owners manual PDF
    • By kaidella
    • By jhamrick75
