Recently I noticed gas leaking from under the gas tank on my 2005 250 2x4. As I looked closer it appears to be leaking from the shut off valve under the tank. It's the valve with the handle that can be turned to open, close or reserve. Can this part be replaced? Thank you.
Edited by Admin
Added ATV information to title
  • Admin changed the title to 2005 Arctic Cat 250 2x4 Gas leak
So the 2 nuts that attach the fuel valve up into the gas tank are really tight. I have tried different metric and standard sockets and they won't budge. I can't see underneath them but was wondering if the bottom of those nuts have a star pattern or hex pattern to remove them?
I  can't tell  you  how they're  locked , but if it  might  be with thread locker , like  Loctite , you  could try  heating them  up  good and  hot  with a soldering iron.  Empty the  tank , leave the  cap  off  and  no  open  flames  to  heat  the  nuts  with..  Heat  on them  will kill  any  locking compound if present  and will likely  help to  loosen the nuts if they  are mechanically  locked with a star  washer or  other means.
    • By LCP92
    • By DexKing
      I recently got my hands on a free 2004 Recon that the owner had zero information on the machine or the history. Long story short, a little troubleshooting and research revealed i needed to replace the timing chain for it to stay running. when i opened the case, it the chain was so horribly stretched, that the tensioner pivot arm had play between it and the chain! I also found the oil pump chain totally disconnected from the sprocket due to being completely worn out. I tore the whole engine down and rebuilt it from the bottom up finding little things here and there that needed to be replaced. Upon inspecting the top end, i didn't find any bad/excessive play in the crank, rod bearings or wrist pin. Now the machine runs great, but even after 2x adjusting the valves, the chatter is way more than you'd expect from a honda normally. My neighbor is an auto mechanic by trade, and i asked him to take a listen. the look on his face when i started it and it was chattering like that was priceless! He mentioned that maybe the valves themselves might be wore out or stretched. my question here: what all can cause the excessive rattle up in the valve cover aside from valves being out of spec? Everything else seemed to be in decent condition as far as rockers and guides go. I am fairly new to small engine/ATV repairs, but am learning as a hobby and have a fair amount of knowledge with how to do some wrenching. Thanks!
    • By DPDISXR4Ti
      Thanks...
    • By PolarisRich
      I've never done this before but after reading a few thread I decided to check my valves for the first time and to my surprise it was much easier than I thought.
      My bike is a 2005 Sp 500 HO.
      I first pulled the seat and the right side panel off, and that's it! It wasn't too bad to get at.
      Next I pulled the spark plug out and removed both the head cover ( 8-8mm bolts)
      [ATTACH]1021[/ATTACH]
      then the side cam cover (5-8mm bolts).
      [ATTACH]1023[/ATTACH]
      Also remove the plug in the recoil cover (14mm bolt) to see the timming marks.
      [ATTACH]1022[/ATTACH]
      Next I turned the engine over with the pull cord untill it was at TDC of the compression stroke.
      The best was to tell that your at TDC of the compression stroke is to rotate the engine until the
      timing marks are parallel to rocker cover gasket surface.
      The cam sprocket locating pin will be facing upward directly in line with the crankshaft to camshaft center line.
      Now fine adjust by looking into the timing hole in the recoil cover and line up the upside down "T" on
      the flywheel into the center of the hole.
      Now using a feeler gauge, slide the .006" (.15mm)blade between the top of the valve and the bottom of the adjuster and adjust accordingly
      [ATTACH]1024[/ATTACH]
      [ATTACH]1025[/ATTACH]
      To adjust, Loosen the locknut (10mm) and check clearance with a feeler guage. Clearance should be .006" (.15mm) for both, intake and exhaust valves. Turn the adjuster with a stubby flat blade screwdriver untill the proper clearance is achieved then tighten the locknut (5.8-7.2 ft. lbs) while holding the adjuster in place with the screwdriver. Re-check the clearance with the feeler guage one last time and re-assemble the covers (72 in.lbs) and plugs.
      The only thing that i noticed was that I had to clean and silicone the side cam cover other than that I found the whole process rather simple.
      I'd give it a 4 out of 10 on the skill level scale.
      I hope this helps!
      Thanks Rich
