2005 Arctic Cat 250 2x4 Gas leak
BosoxBruce
Recently I noticed gas leaking from under the gas tank on my 2005 250 2x4. As I looked closer it appears to be leaking from the shut off valve under the tank. It's the valve with the handle that can be turned to open, close or reserve. Can this part be replaced? Thank you.
Edited by Admin
Added ATV information to title
  • Admin changed the title to 2005 Arctic Cat 250 2x4 Gas leak
I  can't tell  you  how they're  locked , but if it  might  be with thread locker , like  Loctite , you  could try  heating them  up  good and  hot  with a soldering iron.  Empty the  tank , leave the  cap  off  and  no  open  flames  to  heat  the  nuts  with..  Heat  on them  will kill  any  locking compound if present  and will likely  help to  loosen the nuts if they  are mechanically  locked with a star  washer or  other means.
    • By 86ccord
    • By Mhatayas
    • By justent_88
    • By Mhatayas
    • By BruceG
