hello from Poland :D
By Johnfj44
The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
By Werewolf
By oxidized_black
Please visit the downloads section at https://www.quadcrazy.com/files/
By Ajmboy
By Spritee1
not sure where to look next
