On 2/28/2020 at 5:59 PM, Panupong Pradchaphet said:
I have a 2018 Sportsman 450 HO and from time-to-time I hear what sounds like exhaust noise through the cowl near the gas tank.  Could it be an exhaust leak or am I hearing something vibrating?
through the cowl?  not sure what you mean
Check the exhaust gasket ring between the pipes,as it wears out it gets thinner till there's only a steel mesh left.
As for the shift linkage vibrating,sand down one or two halves of the shift linkage fibre 'til it makes a good fit.
The 450 has it's bad and it's good days,with the hydraulic cam chain tensioner  the main culprit. It makes all kinds of ticking sounds depending on oil temperature and pressure.
You can confuse it with a slight exhaust leak or vibration. I changed the exhaust gasket ring and it solved part of the noise but you can still hear the cam chain under acceleration
While noise disappears when decelerating. I need to convert my tensioner to manual but have to make sure it works, 'cause there's no parts dealer in Peru. You have to
be patient and check/repair items one by one . Most people  switch parts for new ones hoping it goes away but that's rather expensive . I would buy a manual tensioner to start
with and once the chain noise is gone you can finally adress the other sounds.
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By Mhatayas
    • By Trent Finnessey
    • By KSIM
      View File 2018 CF-MOTO Z-Force CF1000US-2 service manual
      CF-MOTO Z-Force (CF1000US-2) (2018) service manual
      Submitter KSIM Submitted 03/19/2025 Category Other Brands UTV
