So here at the old household we came up with an agreement... If my 99 Bayou 220 doesn't sell my May 16th then I'll keep it, pull the motor, fix the issues, and get it running.
Just in case it doesn't sell... Here are the problems I gotta fix:
Clutch: The clutch adjuster is, I do believe, stripped. It just never meets resistance. My brother did overtighten it, so it's a good possibility.
Starter: Both bolts are broken off... One at the head and one flush with the block.
Brakes: The left side brake handle (also parking brake) broke clean off. The cable is still there (although the end is ripped off), but the handle is gone completely.
I'm thinking I might just influence the bid a little bit, so I can keep it...
The 220 bayous are a dime a dozen.  Unless you have the parts for free and the experience to pull the clutch, get the starter bolts out of the cover without damaging the engine cover etc then throw on a brake handle too boot i would say $350 is a fair price negotiable down to $300.
Heck you could probably get more money parting it out.
Plastics are worth $250 in very good shape, and the racks get you another $60 a piece.
Bayous here in the south aren't readily available in decent running shape. Most of the decent 2wd were discarded in favor of 4wd so they are usually too far gone to bring back. Last one I flipped was a 98 220 I paid $200 for and flipped for $500 and that was a bit low but it was profit and gone in a couple hours from listing it. Have another one bought for $300, it's a complete 300 2wd, should fetch $650 or so. To OP in this thread, I say make it a rider if you have the skills and then keep or sell.
    • By Cj Winds
    • By Ant-Knee
      I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By marlon smith
    • By jeffrocdx
