2000 Yamaha Bear Tracker idle/starting issue
Similar Tagged Content
By Jride937
Have a 2002 Yamaha Bear tracker 250, everything was fine then one day just lost power. Battery is fine, have 12.53 volts coming out, but I have no lights no start no anything. Looking for a wiring diagram
By David Goff
So i have an old yamaha bear tracker that was given to me from an old farmer I know. I decided to refurbished it and fix all the quick fixes on it. I am pretty sure that it is either a 1999 or 2000 based upon the original wiring harness. Little did i know when I bought a new to me wiring harness from ebay that it was from a 2003 or 2004. My question to everyone is do I need to have all the stop switch assemblies hooked up? I think there are three on the 03/04 models and only one on the 1999 to 2000. Any help I can get for this would be great. I haven't run it yet due to the motor and crankcase is in two totes.
By Timothy Doerr, Jr
Hey y'all. I have a Yamaha ymf 250 BearTracker. I got this thing for free from people whose son tore it to hell. So it wasn't in great shape to begin with. i.e. no indicator lights (neutral light for instance), no ignition switch or key( wires were twisted together to make it run), get the picture yet?
So when it ran it ran rough and I got it running for a year or two, just something fun for the kids to ride on with me on gravels.
Now just randomly, the start button stopped working so I had to jump the solenoid, then put a temp start switch in. Kill switch would still work.
However, the thing has no spark what-so-ever. I've check continuity through the start button and it shows the contact is working, ohmed out the stator, everything is in spec, the reg/rec tested fine as well. I've replaced the solenoid on the off chance it could've been bad and the cdi unit as well, along the the little solenoid relay unit. I'm still getting no spark. The spark plugs is new as well and the coils to the plug have been tested and are good. I've tested and trouble shooted everything I can on this quad and no luck. I watched countless YouTube "no spark" situation videos and it's not helped. Does anyone have any tips or tricks I could try? Would really appreciate some input on this. Thanks!
By payne
Have an Bear Tracker 250. Dont have the manual or any literature to help with. Anyhow, starts with pull start in gear, and electric starter doesnt work. Also, neutral light doesnt come on. Where should I begin?? Need some direction on troubleshooting all this. Thanks a million.
By K L Buck Naff
Trying to replace the carburetor on my 2003 Bear Tracker 250. Two brand new carbs in a row from different suppliers. Both leak fuel out over flow and intake as soon as I turn the gas on. Any ideas. Am I doing something wrong?
Similar Topics
By chimmike
Picked up a 98 Quadrunner 500 for a song. It's in rough shape, but funny enough it turned over and fired on starter fluid. Fuel lines are rotted to snot and the inlet tubes to the carb are rusty. I have a rebuild kit for the mikuni, but I'm wondering if anyone has used any of those alternatives on Ebay or Amazon that say they fit?
By JacobSlabach
I have a gentleman that asked me to service his bayou for him. I have always wondered what oil should be used in atv engines? Pros? Cons? What weight should be used in what type of weather? Is there one kind that I could bulk buy and safely used in any quad I worked on or owned? What about performance? Engine Life? This has always been a 🤔🤔🤔 area for me with quads as far as why you would use one type of oil over another....
Thanks!
By Mezzy
My 2005 Kawasaki banshee runs great, perfect at sea level and starts right up has a great idle perfect performance till I get up to 4000 feet and struggles to start won’t run hardly at all till warm. Anything I can do to the carburetor in a quick type adjustment?
By Quad king
I am not sure what is wrong with my King Quad. I had a new carburetor put in 6 months ago, just replaced the fuel pump and added an in-line fuel filter in. I have been trying to fix this quad for a while now and do not know what is wrong with it. It idles fine and runs great as soon as it is fired up, you can Rev it and stay in first gear with 100% power. As soon as I drive 10 feet it looses all power, I mean it is sputtering and doesn't move at all, but when I let off the gas after it sputters it idles fine. I will attach a video of what it is doing.
Snapchat-1290161440.mp4 -
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
