- [[Template core/front/widgets/relatedContent is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Similar Topics
By Fittzy
So I have a Polaris predator 500 and everything works on it but not getting spark and no power going to CDI box. Please help
By tomlad
hi all first post just found forum and the manuals / wiring diagram BIG THANK YOU
im struggling to find the vin number on my frame? I m told left side of frame , lower, nr. in front of the gear pedal ?? haven't found it yet , is it numbers stamped on the frame or a commission plate ??
main prob. no spark no power to coil , off to study the wiring info I've just found
thanks again. tom
By AKMichael
Hello All,
I have a 1999 Yamaha Big Bear 350 4x4 trying to get fixed up so my grandson can go out in the woods with me.
We have owned it over 10 years. It got harder to start, until it finally would not. Replaced the carb. Right afterwards, it started and ran nicely, but after turning it off, would not restart. Tonight I used starting fluid and ran, then died. Adjusted the idle up a little, used more starting fluid and ran great. It idled about 15 minutes. Turned it off, and restarted. Ran it around the yard about 5 minutes. Turned it off, and would not restart.
Any ideas or suggestions would be greatly appreciated!
Thank you.
By vtech
I have a 1993 Bayou 400 4x4 and I have no spark. I tried 2 new plugs and nothing still.
I have checked the CDI black wires to body of the box for continuity and none.
It turns over but no spark, not sure where to go from there.
Any advise on what and how to check other components would be awesome.
Thanks: Garry
By texaskaw
been acting up for a couple weeks.running fine then dies,no spark at plug.wait few minutes start up again runs for maybe hours.also sometimes it will run great then it starts losing rpm.will not wind up to higher rpms then it will pickup and go for awhile.well now there is no spark any time ,nothing....
