By rjsummer
By middlebrookgt
By Old55
Selling 1994 king quad. $400.00 Complete quad. Engine is stuck.
Located in Highland Mi. 248 514 0888 Old55
By geekmonster
I need a service manual for a 2001 lakota sport im having issues with my oil pump getting jammed
By JORDAN6475
Hey everyone I'm hoping someone can help a guy out here!
I recently bought an Apache rlx400cc for pennies iknow it's Chinese but I thought it could do with a new life with such low mileage on it.
I serviced it and went to start it up to find the starter motor just spins? Is this a simple fix everything seems okay it has enough power to start the engine so not sure why it won't start however these bikes do have a pull start so it started straight away but after starting it a few times it started to slip when pulling I took the case of to find the teeth where broken on the receiver side the pawls are fine but I can't find a replacement anywhere as a matter of fact I can't even find out what it's called so I'm stuck!
If anyone can tell me what this is called please share with me.
