So i have had this trx 250 that i brought back from the grave. Long story
but got it running and the master cyl eye glass was broken out so it hasnt worked in years.
I replaced it, filled and bled the cyl, bled the brakes, I dont see any air coming out when im bleeding them
but no matter what no pressure on handle. Will stop the turning wheel if spun by hand but wont hold at all.
I adjusted the brakes also, checked for leaks at the brake cyls, all good. No leaks at lines or fittings, I have put a lot of fluid
throught them and i know the routine as i did brakes on autos for years. Have new washers on master cyl, I would hate to replace
parts knowing their good. Funny thing, few years ago same style vehicle i bought same broken master cyl and same problem after
replaced. No pressure, Any ideas? Pretty simple system but maybe you guys have had similar problems. Thanks Az
Just so you know I have replaced the complete master cyl, not just the glass. Az
Will the MC pump fluid out if you just crack a line?  If not, then it's probably defective out of the box.  Sometimes air pockets are nearly impossible on those little MC's so often times you have to power bleed them with a suction gun.
Rather than suction , pushing fluid back from the wheel cylinder bleeds to the master cylinder can clear  an air  lock  if that happens to be the problem. Used that a few times on old auto  systems that  didn't want to  clear trapped air through normal bleeding.
I bled the m/c first, gravity fed both lines forever, Pumped up and bled
the standard way, barely any tension on lever, it does come shooting out of the bleeder
when bleeding but still not enough to activate brakes. I even clamped off 1 line at a time.
When doing so it increased the tension on lever a lot but still not right. I even was tapping on the brake line where
it connects to the wheel cyls, and also at the y connector, still same condition. Easiest things seem to mess with
you the most. Like i said before also had another one with a broken m/c and ended up same problem. Never did get
enough pressure to slow you down. Would not even keep you from rolling it with the brake on. Dam Hondas! Az
well some one wanted to but it so away it went, still no front brakes,
guess ill never know but sure ill get another with the same problem. Till then , Az
    • By BillR94
      Thank you for your time
      Bill
    • By Rick Shropshire
      I’m looking at replacing rear brake calipers on both of my blasters. I was told that the only thing available was a hydraulic upgrade? I’d prefer the original. Anyone?
      I decided it was time to do the brakes on the Eiger, i got it a couple of years ago and worked out all the bugs got it running good and ignored the brakes. None on it ,front or rear. Decided to attack the front first no pressure on the master cylinder and screws were stripped out on the reservoir, took the banjo bolt loose and pure water ran out, glad i didnt wast time on drilling the screws out, pads were shot also. Pulled a couple out of my box o parts. One was for right hand so wouldnt work, the other looked fine until i opened the reservoir and full of white powder. Cleaned it out anyway and tried it, only would build up a minimal amount of pressure. So no go on that one. So ordered new master cylinder and pads, so now i have to hurry up and wait.
      On to the back they are drum brakes so i knew this would be fun, 20 year old machines that have been mudded and abused for that length of time nothing comes off easily. The engage shaft was froze solid from corrosion. Getting that out is easy but you have to get to it first.
      The center nut was supposed to be 30mm but it wasnt it was 27 the only size not in my large set, go figure,
      The previous owner decided it was a good idea to JB Weld the cover on making it near impossible to get off, had to chiesel it off.
      The mounting plate was a different story, nut was tight tight tight took my biggest impact two or 3 times hammering on it to get it loose after soaking all night in PB Blaster. Got it moving along the splined shaft easily but wouldnt come off, when it got to end of its run it would just stop, ended up using 2 24 inch pry bars one on each side, past the point of being gentle and it finally came off.
      Got to the drum and it came off easily a little suprised at that, it was full of mud and rust, i knew it was going to be bad because there was a snorkle on it when i got it, never buy one with a snorkle, they are highly abused to the machines limit, but i got it cheap .
      Finally got in there and no shoes left and a complete mess.
      Lots of mess to clean up.
      Got it looking a little better.
      Lots of cleanup later! Waiting for new parts.
    • By 97kingquad
    • By PupATV
      Hey guys! I am new here to the forum and need some help getting my Polaris 325 Magnum 2001 Running.....So I got it for free and it has never run quite right...I put a aftermarket carb on it last year and it was running fine but it only went like 20 maybe 25mph max......But then the needle and seat sealed leaked within a yeah and it flooded it REALLY bad so I changed the oil because it was full of gas. So then I put a genuine Polaris carb on it and I have it set to all the factory specs, but it was still not running right....So I replaced the ignition coil and the spark plug and that solved one of the problems I had (It would bog down and stop running when i would go up a hill) But it still didn't have that much "Punch" to it like my Kawasaki Prairie 300 ans Suzuki Kingkuad 300.....So I replaced the CDI but it's still not running right! It's acting like it rich kinda....So it runs mostly okayish when I have the airfilter on but the top of the airbox off but as soon as I put the airbox lid on it like REALLY bogs down and wants to stall really bad. I have the carb at the factory specs and it has a pretty new fuel pump so I have no ideas whats going wrong! It still nly has a top speed of only about 30-35mph and it sounds like it's choking the whole time! Thank you for sticking to the end, and I hope you guys can help me!
      -PupATV
