Another one back from the dead (1997 King Quad 300 LT-FWDX)
Hagbard
Imgur says it was the Yamaha tag, apparently there is quite a rabid fandom.   With such a low financial barrier to entry, I can see why they’re so popular.
The oiler was long gone when this happened, there’s an aftermarket delete plate where the oiler should be, and it isn’t anything recent.
this was the condition of the wrist pin bearing when I removed it:
I heard from the kid today, and extracted out of him that it was just a parts bike he picked up last week for the wheels. Which is funny, because the KFX80 was essentially the same exact thing, so we traded parts bikes.
Not just that but the blaster, warrior, banshee, and raptor are unique machines.  The only thing suzuki ever had was the zilla and maybe the king quad if all the gears make it unique.  Honda is the mediocrity and kawasaki the third wheel leaving polaris as the village idiot.
Maybe someone didn't know the oiler was disabled?
I don't know how else to produce that damage to the piston and bearings other than lack of oil.
Did you examine the sleeve for evidence of seizing?
39 minutes ago, Hagbard said:
Like, um... take my money.  I get a little extra gasket for the next go around.  Even at $145 it's a bargain made in China.
Like, what inflation???  lol
Love the hierarchy of quad supremacy lol! It's funny because it's true. Yamaha is a consistent finisher in racing too. YFZ450's all day long. I see EVERY SINGLE TEAM at races driving around on a Honda utility quad between motos. No matter what bikes they ride, Honda is nearly ubiquitous as their go-getter. Speaks to reliability and not much else I suppose.
My suspicion is that someone just grabbed the wrong gas can to fill it up. Sh** happens. More often than not.  Sleeve looks clean like a broke-dicked dog. Just a little flash rusted. It looks like the piston was reused AFTER breaking rings. I bet someone re-ringed it, put on a new jug, and sold it cheap to some kid who failed to put premix in it. Just spitballing but it seems most likely.
My personal theory is that the Chinese are trying to undermine Japan's secondary market by flooding the zone with cheaply made products that fit well enough and cost 1/8th as much.  Law of large numbers. But I'm no economist.
They have the 5-valve head.  Everyone else is stubborn I guess.  Or maybe it's like pro wrestling.
Pretty much.  It's almost like Honda goes out of its way to not do anything particularly well other than always working.  Maybe being ok at everything but good at nothing is their shtick.
So the piston fried in another jug?  Yeah that makes sense except at what point did bearings fall apart?
That sounds about right.  You have too much sense for an economist lol.
This turned out to be a nice little score. Just happened to have a foil decal from that little sticker begging project that was a perfect fit ;)
B66346BC-D375-41D1-A949-840BD3EE8956.thumb.jpeg.33e4622ef94effdce6cc4bfe9901b81d.jpegF76BB53A-8B15-4123-9A0B-5E3B54E31C4E.thumb.jpeg.5ac6eb5f932b61c2d19937b0f7e4a8bf.jpeg
Cleaned up pretty good with some Dawn and CameO polish. Have to grind down some bubblegum and see if they actually achieved penetration or if it’s just a bunch of crud sitting on the top of a fissure. There’s some evidence of blow by where the core mates with the can but a little work with a peen hammer and some decent rivets in place of junk drawer hardware should shore that up.
Repacked it last night, made a video with the GoPro to test it, and can’t find the cable, so pics will have to suffice. The sheer luxury of my workspace is breathtaking, I know.
Rest assured they don’t do justice to the craftsmanship and materials choice. Once again I’ve selected the finest available repacking kit available in my attic.
I like to use the backer paper like a rolling machine to get the mat nice and tight 😂
I forgot to mention that I discovered the core was about an inch short of where it ought be, which was disappointing but not enough to rain on this parade of jury rigging. I found that the tailpiece from a bathroom sink drain is approximately the proper ID on both ends to accommodate the core, and the actual tailpiece of the silencer itself. Pretty much acts like a quiet core insert.
I think I should get extra points for that bit of ingenuity and/or frugality.
I don’t think it should amount to enough added back pressure to foil the efforts of the exhaust tuning, as I believe it’s well beyond the stinger and shouldn’t have much effect on power. 🤞
Edited by Hagbard
I looked up the quiet core and it looks like it goes inside the pipe to increase resistance to exiting the pipe which gives the exhaust more time to quiet down.  I did the same sort of thing with my 250 by sticking the next size down pipe in the tail pipe.  The reduced diameter causes just enough backpressure to make it quieter.
But what it looks like you have is a pipe over the top of the other pipe which doesn't increase backpressure and you've covered half of the holes which seems like it would make it louder.  It will work but it might not be very quiet.
The muffler works by dumping energy into each of those holes as the wave moves along the length.  If you reduce the holes along the length, you reduce the damping capabilities.
The inserts can't go over top of other pipes because they have screens on the ends.
Finally got parts in the mail and built the Blaster motor on Friday night, dropped it in the frame Saturday morning and then finished up the LT80. Patched the leaky gas tank with some plastic weld epoxy putty, hooked up the brake cables and put the new DWT tires on the front. Looks like a stanced little monster truck lol.
Carolina Squat Quad
Also picked up an ultrasonic jewelry cleaner - HIGHLY recommended for carbs!
Yeah, it's just as wide as I can get it for him to learn on without tipping over in the yard. I realized that the treads were reversed, so I switched sides after this pic. Have the throttle governed down so he can't go crazy just yet. This kid has a tendency to try and ram things, so I need to minimize the possible damage. He could use some upper body strength anyway =P
Cleaning the Blaster's carb tonight and I might just try to fire it up tomorrow. Got it all put back together for the most part.
Edited by Hagbard
Be careful.  I don't have any bumpsteer yet when I clipped a tree the handlebars hit my leg with such force I thought I was gonna die.  It was like taking a louisville slugger to the femur.  It was all I could do to compose myself enough to turn the key off to stop the vibration.
A buddy clipped a tree and broke his arm bones near the hand.  Cost him $20k to pin it back together.  He's the one with the 700 king with the backwards caster.
  • Thanks 1
On 9/26/2021 at 10:49 PM, JustRandy said:
The one on the left has got to be the 250 cam.  Look at that duration!  The other two are so similar that I can't tell which is the 230 or 4x4 cam.  I'm guessing the one in the middle is the 230.
So... back to our cam discussion~
I haven't pulled the trigger yet on the 250S cam in some desperate bid to find a thrifty alternative. I'm a fukn penny pincher at heart, and even though I *could* spend $140 on a cam, I don't *want* to lol.
I've confirmed what I suspected to be true - that Suzuki used the same OHV design in a shitload of motors with minor tweaks here and there, and the cams are physically interchangeable between a wide variety of bikes and quads.  It's just a matter of finding the actual specs of these different cams and the purported "upgrades" offered by various aftermarket companies, because I discovered most of these companies don't actually MAKE anything, they buy it from Megacycle. See pg 49 here: https://www.megacyclecams.com/catalog/catalog_optimized.pdf
Lots of good info in these two threads:
https://thumpertalk.com/forums/topic/367643-dr-z-125-cam-info/
https://thumpertalk.com/forums/topic/826160-dr100-performance-mods/
ANY Suzuki CAM (and much more) from
dr100
LT125
GN125
DR125/DRZ125
LT160
LT185
DR200/XF200
LT230
LT250s
KQ300
family WILL FIT, as they are basically, the same engine with different Bore x Stroke.
So on top of THAT, there are also China bikes that borrowed, stole, or licensed the design from Su Zu Kai, so there are also now aftermarket purported upgrades for those as well.  Whole bunch of these on eBay for around $45 shipped from China.
https://www.ebay.com/itm/264449513003?hash=item3d926b562b:g:LdkAAOSwmHhda2Fr
I've messaged the seller trying to find actual numbers to compare by, doubtful I'll get a meaningful response, but I tried ;)
PS - I was looking through this ancient as* thread on ATVConnection, I think it started out about cams and turned into a navel gazing exercize about LED's with a very familiar squid named JustRandy ;)
https://atvconnection.com/forums/suzuki/226867-85-88-suzuki-lt230s-quadsport-help-1065.html
More info in here from Zomby Woof:
https://advrider.com/f/threads/the-dr200-thread.229927/page-12
"The Hotcams cam for the DR-Z125 wil, in fact work, and be a reasonable improvement over the stock, and unbelievably mild DR200 cam.
There are a number of available options from a number of other custom grinders.
Megacycle having probably the best looking available profiles.
For reference, I will provide you with the real numbers."
The hot cams specs. are
Int
.324" lift (.240"lobe)
215.5 duration at 1mm
Exh
.315" lift (.240" lobe)
stock DR200 cam
_________lobe lift______valve lift____Duration at .050"
Intake____.245"________.320"_______204
Exhaust___.230"________.290"______ 200
Stock LT230 cam
Intake____.230________.300_________214
Exhaust___.200________.245_________212
How did you determine other companies buy from megacycle?  They have such insane lift that I've never seen in other cams.
Even if you did get a coherent response I wouldn't trust it.
Yeah that was the link I gave you containing The Vault with all the 230s info.  Anything you could ever want to know about 230s are in that thread, plus a bunch of other random stuff you'll have to wade through to find the nuggets.  I wonder what ever happened to that poolgod fella.
I just signed up there to ask the valve specs and it ballooned into all that.  I don't know why I tend to have that effect on threads. :/
Making heads too.
I wonder what the intake valve size is on those heads.
Hotcams is a stock 230 cam.
Except for the lift which gains you nothing other than having to accommodate it.
Webcams has the best profiles but you have to send in your cam and rockers for welding.  Webcams will grind any profile you request.
Almost everyone ran webcams stage 2 back in the day.  Stage 1 is pretty close to the 250S cam.
I posted the specs of webcams, hotcams, and megacycle on one of these pages here.
I don't know how successful you'll be at finding a good cam cheaper than $140.  It might be easier to do another boat cover than all this research, especially if you ultimately find the 230S cam is pretty ubiquitous.
Probably the cheapest way out is to weld and grind your own cam.  I did that once to a bayou and it worked surprisingly well.
The Megacycle tidbit was in some DR200 or DRZ125 thread, guy managed to pry it out of a couple folks after flexing his "I'm a machinist, and I grind cams" line.
I just realized I promised to steer you toward a decent sewing machine and never actually did that.
Simplest route to take where you want to be is to find a used Singer 29K on craigslist in your are. Drive a couple hours and spend up to $500 if you have to. It's the machine you want. It has a walking foot, and a very unique feature called "universal feed" which means the foot can be turned 360 degrees and sew in any direction.  They're ancient, bombproof, copied by everyone (mostly poorly) and you can still buy parts for them if needed. It's basically a staple in any old school cobbler shop. The Chinese Leather Shoe Patcher you can get on eBay for like $60 is a pretty close approximation of the 29K, but it's janky as all hell.
Other used machines to be on the lookout for are Consew 206RB-5, and Adler 69. Those are the two I use every day, and I still want a 29K, just for grins, but I don't have the space or time for one just yet. 29's can tackle some pretty heavy stuff, well worth the money, and great for repairs in particular.
Are you sure I need all that?  You're sweating $140 but having me shell out $500 for something I don't even know how to do lol.  I don't even know how sewing machines work: how does the thread get hooked from under the cloth?  I'm totally clueless.  Maybe I need something with training wheels.  Is there a KFX80 of sewing machines that I could cut my teeth on?
13 minutes ago, Hagbard said:
I searched in the Southeast, and didn't find squat for decent industrial machines on CL
Odd since this area is the textile capital of the world.  There should be old factories plum full of them.
Just giving you the benefit of my experience going through the motions and buying successively heavier and heavier duty machines that just weren't up to any task beyond making drapes. Light muslin drapes.  If you can find ANY walking foot industrial machine, you will be in good shape overall, but the best thing to have is a compound feed walking foot.  The Singer 29, 29-4, 29k etc. are all unicorns in that they have that universal direction thinger. Illustrated here by a rather annoying limey:
Most machines do NOT have a real walking foot. You're thinking of a presser foot. Walking foot is two alternating presser feet, so there's always a foot on the material being sewn, which keeps the layers together and prevents bunching, sagging, pursing, etc. Compound feed is walking foot where the needle bar ALSO moves in time with the inner foot, so there's an additional means of securing the layers, which is important when sewing thru multiple layers of heavy material. Industrial machines are generally heavy, cast iron machines with forged internals, versus your average Bernina or Singer home machine available at JOANN Fabrics for $400 which is made almost entirely of plastics and nylons and wilts at the sight of more than 4 layers of mom jeans denim.
I appreciate the insight!  It sounds like the walking foot is an imperative feature, especially for beginners.  How important is it to have the compound feed?
What happens to a sewing machine that isn't heavy cast iron?  Is it that you can't use them a lot, like in a factory?  Or is it that they won't sew thick material?  How do the plastic ones fail?
I watched that and a few more videos and realize I need to watch some more, maybe later tonight.
Having the needle in the fabric as the fabric moves seems like the best way, but how much better is it?  Is there ever a time where catastrophe would have been avoided if the needle had traveled with the fabric?  Or is it a lot of intricate mechanism without any real benefit?  I'm referring to walking foot vs walking foot + needle.
    • By hardcastle
    • By Charlesbrown
      Heres my story. Kinda long. I guess I was a late bloomer when it comes to quads. I had never ridden a quad in my life. Rode Dirt Bikes as a kid growing up. Back in Oct of '06 I found a Mustang on craigslist. Took it for a test drive one morning before work. Fast car. 351 Cleveland. I had planned on meeting the guy again after work. For some strange reason thats still to this day beyond me, I stopped in Hillsboro MotoSports on the way home from work. I had 6 Grand on me. There was a left over '05 sitting by the front door. It was on sale for $4999. It was $5499 OTD. I didnt even look at anything else. I knew nothing about quads accept I thought it really looked coool and I had the money in my pocket to buy it. I was sitting on it when the salesman walked up and asked... "Can I help you?" Without hestitation I pulled 60 Ben Franklins outta my front pocket and said "I want this Quad. Load it up in my truck." It was just about dark by the time I drove away from the shop. BTW, I didnt bother to ask my ol lady if I could buy it. LOL. Anyway, I took it by the house and showed her. She was kinda stunned but not mad. We drove over to a friend of mines house and unloaded it. I took it to the field across the street from his house. HOLY CHIT!!!!! I was surprised by the power. I had it for about 2 weeks and took it to Sand Lake. I was there a few hours and rolled it on a banked turn at the top of the bowl right before you get to the one-ways. When it rolled, I flew off and landed on my belly. The quad came bouncing and landed on my back. For a month I couldnt even walk. I was scared of it. I considered trading it for a 250EX. Went back to the shop. The salesman said..."Dude!!! You dont want a 250EX!!! Trust me. Just get used to it" I still wasnt convinced. I put it on craigslist for $4000. Calls were coming in. I had a guy that wanted to come look at it that evening. I decided to take it for one last ride at Browns Camp before I sold it. I was still afraid of it. After about 5 minutes I started feeling comfortable on it again. I decided right then, I loved my Honda 450 and would learn how to ride it instead of selling it. That was late Nov of '06. Work was slow for a Painter in Oregon. My new job everyday? Going to Browns Camp and ridding my Quad. I bought my Girl Friend an '02 Blaster. I rode my 450 for 4-6 hours almost every single day for 3 months. And yes, I know my way around Browns Camp pretty well. LOL. In March I bought her an '06 TRX250EX (Thank God I didnt trade my 450 for one of those) LOL Since then, I have become totally addicted to quads. I love them. Couldnt imagine not owning at least one quad. Luckily I have two. My "07 was $6500 OTD in July of '07. Bought it for my Girlfriend. Traded in her 250 EX. A month later we broke up. So, I wound up with two Honda 450's.
    • By Sofaspud
