Honda Pioneer 500 & 1000 Service Manual link
By DaveswMN
Thanks for any thoughts.
By Jaiidutch
ok so ill try and make this as short as i can i really hope someone here can help me figure this out...
bought a 2001 Mojave 250 from some one not running.. was running till ??somthing?? happend. was told before it stopped running it had a timing chain slap sound so the chain was replaced.
got the quad home and did a compression test results were 0psi...lol decided to break the engine down n see whats going on. found a brand new timing chain installed and yet 2 valves pushed into the head..so i ordered a top end gasket set and all new valves and lapped them in. while the head was off i did a broke man leak down and filled the cylinder with thin oil and let it sit for a few days and none of it leaked so i assume the rings are good. reinstalled the head with new head gasket and valves. re did a compression test and I'm seeing 80psi(i don't really trust my cheap tester). I kick start the quad over and it will run for about 10 seconds and then die. I'm getting good blue spark. cleaned the carb and tried again... i can kick 10 times and it will only start for 10 seconds or so. swapped my carb, throttle cable & thumb throttle from my 87 Honda 250x to the Mojave and same result 10 seconds... had a friend bring over a known good working Mojave carb and you guessed it same results 10 seconds. even swapped to a back up stator that i have and same thing... what in the world is going on! i dont know what els to try
By Shannon
Hey guys, just wanted to know if someone can help me figure out my year and model of my Arctic cat 450.
ALL help is appreciated. 🤟
By Spartacus Stroppel
So I have a 2001 Kawasaki prairie 300 I could not find tough country snow plow... it's a older plow too boot... so I made the plow mount and updated the plow with some skids.
Mount plate is 1/4 steel plate and so are the pin points
The skids are off a moose plow. I got some plumbing black pipe for holders to weld to the blade and braced it with pieces left over from the plow mount 1/4 steel...
1/4 plate cost $45
Skids cost $24
U bolts and other hardware where $20
I got the blade free
By Ryan Geiler
New to the ATV world, picked up a solid used Kodiak 400. It appears the former owner did some sort of modification for a saddle bag or something along those lines--and I'd like to match it up and replace it. Not a big deal by any means but something I thought I would give a shot at finding.
does anyone recognize what kind of luggage/bag/cargo would go where those white tabs are he drilled through that fuel fender?
Thanks again
