Guest Fox300exchic
Today I went riding and towards the end of the day my quad kept dieing while I was riding it. Just riding like normal and it would start to back fire and then die. Do I need to clean my carb or what?
Guest Fox300exchic
Well, I think my carb is about due for a cleaning so Im going to clean that either way. Ill see what happens and check the other things. Thanks. :) I dont know about the wheel though. If everything thing else fails maybe Ill give that a whirl. LOL
The Tors is only a Throttle Over ride System that is supposed to protect your motor from over Revs....I dont think the 300EX has one....Banshee, Blaster do I know....
Anyway,,,,When was the last time you adjusted your Valves and Timed it????
You need proper timing, proper valve adjustment , compression, spark , and fuel:cool:
Guest Fox300exchic
Never. I've only had it since Feb. The guy we bought it from only rode it about twice. Im not sure how often all that needs to be done.
Guest Fox300exchic
Well......
I cleaned the carb and dumped out the gas tank cuz there was serious dirt in there. I know now to never let my sister in law ride it when im not there. That worked
Oh and I dont have a manual DeadAIM
  • 2 years later...
actually it does have something similar but its built into the electric ignition module, main reason i know is because now that i have the mods done to the bike (or golf cart as you may say lol) i hit the limiter often (well ok might be due to being in second or third climbing big dunes lol)
  • 9 years later...
    • By realpilot
    • By OldATVowner
    • By quadnut20
