Honda 300ex dies while riding...
Guest Fox300exchic
Guest Fox300exchic
Today I went riding and towards the end of the day my quad kept dieing while I was riding it. Just riding like normal and it would start to back fire and then die. Do I need to clean my carb or what?
Guest Fox300exchic
Well, I think my carb is about due for a cleaning so Im going to clean that either way. Ill see what happens and check the other things. Thanks. :) I dont know about the wheel though. If everything thing else fails maybe Ill give that a whirl. LOL
The Tors is only a Throttle Over ride System that is supposed to protect your motor from over Revs....I dont think the 300EX has one....Banshee, Blaster do I know....
Anyway,,,,When was the last time you adjusted your Valves and Timed it????
You need proper timing, proper valve adjustment , compression, spark , and fuel:cool:
Guest Fox300exchic
Well......
I cleaned the carb and dumped out the gas tank cuz there was serious dirt in there. I know now to never let my sister in law ride it when im not there. That worked
Oh and I dont have a manual DeadAIM
  • 2 years later...
actually it does have something similar but its built into the electric ignition module, main reason i know is because now that i have the mods done to the bike (or golf cart as you may say lol) i hit the limiter often (well ok might be due to being in second or third climbing big dunes lol)
  • 9 years later...
    • By Spritee1
      not sure where to look next
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
