Air pilot screw adjustment question.
By Gwbarm
I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
By ResQ91
Hi Guys!
Or ??
Dave
By jashadams
Hey all back again with my 1989 moto 4 250.
After putting a new carb on it it's really sputtery, it has new gas and I'm wondering what to tune on the carb to make it idle better. I've attached a video to describe the issue more. The bike is still work in progress but I think the video gets the point across. Thanks!
Snapchat-1142015191.mp4 -
By p5200
By Scoopeddad
I have a 1994 big bear and I am starting to have issues starting. I put in a new starter and selnoid as the at stopped starting with the electrical but will still start with the pull cord. Where and what now should I be looking at to check? If I turn key to on and the switch to on then hit the start button, the bike clicks and then nothing. Lights still work but no response to the starter. Stumped now. Any help would be greAt.
