Assuming you replace the OEM carb with a new OEM carb, then you do use the spec adjustment.  If you're replacing the OEM with a cheap chinesium carb then who knows, those are a mess.  Start with spec and adjust from there and hope that it works.
For what I paid, I'm sure it's a Chinese made but, I just can't afford an OEM replacement. I've got the special adjusting tool and a tach I'll see how it goes. I guess I could rebuild the OEM if need be. Thanks!
Yeahhhh....ALWAYS better to rebuild OEM.  I've been forced to use chinese junk a couple times due to missing carb on some junk ones I've put back together and they never run as good as OEM.  Even if you get them to run pretty decent they usually last a year or two and the cheap rubber seals fall apart.
Yup, I'd advocate for the OEM overhaul over an unknown make any day.. Even with worn slides and carb body, they are still a better bet than some of the aftermarket carbs.
As for the initial setting... some aftermarket use their own, different, threads on the idle mixture screw, and different taper. Set it where you like initially  and adjust it once it's going and warmed up.
If it's the same make and model as the OEM that's a good start, but then they come in different versions for different markets and years as well.. Different markets often have different jets and adjustments.
If it's the same make and model and has the same, stamped in, numbers and letters, it can still be set up slightly differently. Some makes have up to about four variations for a single model and year.. The stamped in numbers and letters are the most specific details, they tell us what jets and setup they have. The general model though can be fitted to heaps of different make and models and have endless variations of jets etc.
Quick question.. the cover on top of your carb, is it squareish with four screws, or an odd shaped cover ?
The stamped in numbers are done when it's set up for a specific bike and market. The after market carbs don't have the numbers, and are not set up for any particular bike or market, they are just set for a general tune which should start and run anywhere..
If the new carb is an exact copy of the original(right down to the threads used for the jets), then you can often swap all the old jets and brass bits, and the slide and needle, from the old carb to the new one to set it up as intended for your market/climate/fuel/altitude..  The idle mixture screws sometimes have different threads though and can't be swapped.. If the new carb isn't an exact copy of the old one though swapping the jets, even if they do fit, doesn't always work so good.
Unless it's the OEM make, and with the same stamped in numbers, it's not really a OEM replacement part.
Yeah that's what I was thinking..  A weld..
That carb is a QB02B or QB02A. The A was fitted from 93-2000, and the B from 2001-2006 models. They both have the same jets and float height, but they will probably have different slide needles and/or emulsion tubes(the brass tube the slide needle slides down into), or possibly slides.
I think, on the carb it's got the  QB02A. I'll have to check to be sure though. If I have trouble with the one that's on it I may check and see what a re-build kit would cost.
20 minutes ago, Gwbarm said:
Never seen a valve tack welded to a keeper, I do some, non text book repairs, but that's got me beat.
Bought a Kodiak a few years ago that had the rocker tip tacked bc the nut was missing but tacking a valve is a new level of haggardety.
Yeah, I got screwed when I bought this piece of sh**, $1000.00 down the drain. All I wanted one for was to go through the woods by the house to hunt and fish.  I figured surely it should be good enough for that. But so far it's proved me wrong. That fat bastard I bought it from should be glad there's laws!
When I got it barely ran the guy said it probably had some junk in the carb. I figured I could clean that out and it would be fine. But, I think it was having trouble starting and staying because It was probably about ready for the chain to jump off then. I've got maybe 2 minutes of actual riding time on it.
The chains have to be really really worn before they jump off..  If they backfire though, or kick back as they are stopping, and the tensioner isn't good.. then they jump.
Is the old chain really really worn ?
This is something a lot of people get confused about.  The pilot screw (air or fuel) setting in the manual is a starting point.  That's why it's an adjustment not a permanent setting.  No two engines are exactly the same.  And yes new carbs - either installed or in a box - are set at the factory but that's why there's a Welsh plug to remove so you can adjust it.
    • By Jdeaton011989
    • By colin james
      View File 2017-2019 sportsman 450/570 with eps factory service manual
      This  is the factory service manual for the 2017-2019 factory service manual for the sportsman 450/570 with electronic power steering
      Submitter colin james Submitted 09/06/2018 Category Polaris ATV
    • By alexwv1863
      I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
      So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
      I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
      I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
