2000 Yamaha grizzly 600 no spark
EugenM
Go to solution Solved by EugenM,
Hi, I have a grizzly 600 from 2000 that has been giving me headaches for a few days.  it has no spark.  I checked everything I could according to the manual and everything was within the parameters and I came to the conclusion that I need to replace the CDI .... when I did the measurements I did not check if the orange cable that goes from the CDI to the induction coil has a connection to  ground (I just checked if it had continuity and it did).  after I put a new CDI and I still had no spark, I saw that somewhere under the fuel tank there was a bunch of cables that were a bit crushed and there that orange cable was stripped and had a connection to the chassis.  what are the chances that the new CDI will be fried because of this?
Thanks!
When the cdi discharges normally it's going through a coil with nearly no resistance anyway..
And, once that wire shorted the engine stopped, so apart from your cranking it over it shouldn't have fired many times.
It might be ok still.   Repair the wiring and try it..
Edited by Mech
Thanks Mech for the prompt reply, I've already done this...basically replaced the cable from the CDI to the induction coil, but unfortunately no positive result. Last night it was already too late to work anymore (UTC +2 my time zone), but first thing in the morning ..that is in 2 hours... I will resume work and hope to find the solution. I will make an update after I find the problem....if I find it of course :)
Need to follow the voltage.  You said you checked resistance but didn't mention voltage.
Have to get a wiring diagram and follow voltage from the battery all the way to the CDI then back to the coil. As well as the pickup coil voltage.
Thanks Tiha,
I have the wiring diagram but today is already late,
I will do that tomorrow...
But I don't know exactly if the CDI have a connection directly from battery, I've checked today the voltage at all the wires that r connected to CDI and didn't get anything....and don't know exactly witch wire need to be with 12V....on the diagram that I have can't read very well what's written...is pdf and when I'm maximizing is blurry.
Thanks for your help!
Eugen, if you test the stator and the trigger coil resistances from right at the cdi they you are also checking the wiring at the same time. Then check for power and good earths right at the cdi. If all those are good then check for output from the cdi when it gets triggered. You could use a test light with a bulb..  the bulb will probably blow but as long as it's not glowing all the time, but just flashing brightly(and possibly blowing), then it is charging the cd and it is triggering.
If you have a read in "looking for a cdi... ", I've just posted some general notes about diagnosing faulty cdi/wiring/stator and triggers, and some other things that can cause it besides electrical faults.
  • Solution
Mech thanks for support!
I managed to find out the problem....
Grizzly arrived at me from another garage with no spark problem, the people where it was changed the stator and the sensor, the induction coil and the CDI...all new...I found the faulty wiring (you can see in the pictures above  ) which I fixed...today I took the stator down again and found the receiver sensor mounted wrong...now it works perfectly.  Thank you for your support! and as a bonus you can see in the video what surprise I found behind the flywheel
Ha..  The other "mechanics:..  They had a spare washer so just tossed it in there.. Good spotting.
Well done finding the wiring problem.. It's funny how often people start throwing expensive parts at things without even checking the wiring or switches..
You know Mech, everyone is trying to fix their problems with small amount of money...and is understandable.... but sometimes they don't understand that probably at the end they spend more that they thought of.....
I'm glad I managed to find the problem...
I'm pretty sure that the wire harness was the main problem....the pickup sensor was wrong fitted by the other guys.
Thanks everyone for support!
Greetings from România!
Does anyone have a wiring diagram for a 07 bb 400 4x4 im trying to get my posts up to acc the downloads my bb wont start via push button i have traced everything and no chaffed wires or anything bad that i can find it will turn over via jumping solenoid posts i changed solenoid and made sure ground is good and voltage is good am I missing something i only see 1 ground which is from battery to frame is there supposed to be one from motor to frame also
Did you check your starter cutout relay, there are 2 relays in harness 1 is starter cutout relay and the other is the reverse relay, they are little square boxes in the wiring harness, mine were blue OEM, but my replacements were black. That got my starter working from button.
  • Similar Topics
    • By Atvguy0901
      Thank for the add on quad crazy. I am new here and need some help with my atv. It’s a older Yamaha Timberwolf 250 that I purchased second hand from an person. I got it home ans started to look into it. He stated it needed a cdi box so I ordered one for it and a battery as well also a key switch cause it did not come with one. I put all the parts on it and when I hit the start button it just clicks and noting else. Thank you any help is appreciated.
    • By Params_sweden
      Hi, I have an EU '94 KLF300 Bayou with ignition issues. I got it last summer and used it for about 20 hours, then one sunny day we used it for about an hour, parked it, and then it didn't want to start again. It has a *really* weak spark, I've only been able to see it once while testing.
      I'm just getting started on this, I'm going to go through all the weak/no spark trouble shootings from the manual. Since I've already invested like 10 hours digesting the manual and forum threads that I possibly can, I thought that it would be nice to create a thread like this in case I come up with a solution that can help someone else.
      So far I've replaced the spark plug, I will replace the spark plug cap with a NGK VD05F (5kOhm resistance). I'm going to check the resistance in the pickup coil, stator coil and ignition coil next. I have tried two CDIs, right now I mounted the original CDI which actually gave the most output to the spark plug out of the two
      A question for you, is it possible to make any assumptions about the CDI by measuring the resistance like in the manual? There's a "resistance table" that you can refer to when measuring between the different connections. I'm asking because I haven't yet seen anyone in the forums that has mentioned that they've measured the CDI resistances and made any conclusions from that.
      I'll attach a photo of my Bayou
      Pär, Sweden
    • By Filthy_Mule777
      I'm currently pulling my hair out over a customers 98  bayou 2x4 KLF300b. I've changed every electrical component on it twice and in a couple instances three times. Still no spark, I am baffled. Initially customer brought it to me complaining of a hard start no start situation and in fact, it wouldn't start. I changed the starter relay, spark plug,  CDI box, and starter circuit relay after which it fired right up ran very well but then started having issues with the neutral switch/light where it wouldn't come on and wouldn't allow it start or even turn over. I found in the wiring harness a loose connection, I got it taken care of and secured and that solved the problem. So now that it would crank up again and run fine I called the customer over to test it out see what he thought as I've never heard it run before and I wanted to get his opinion on how it was running. Customer ride it around a little bit pulled it back on my carport and turned the key off and said it was great, and had never ran better or started so easily, then we set up a time for him to come pick it up the following day and he left. Well where he pulled it on my carport and shut it off was in the middle of the carport so I jumped back on it to park it off to the side,  crank it up no problems put it in reverse went about maybe 18 inches and it stalled and ever since that point it has not had spark or run. I replaced the CDI box again with a better brand, I replaced the ignition coil twice put another starter relay on it and I've also changed out the stater and the pick up coil (pick up coil twice) and I'm just I'm lost I don't know what else to do to it. I've had this customers  four wheeler for four months now whereas he's a patient guy I need to get it out of here so I can move on to something else. I've seen dozens of threads across  different sites for off-road, 4 wheelers, ATVs, UTV's, whatever and they are all experiencing the same sort of issue but they never ever post hear the problem was or  the fix. So I'm hoping somebody here has a little bit of knowledge on this particular issue sent since it seems to be so widespread.  Thanks in advance for any help or suggestions.
    • By p5200
      I seem to have no resistance at all on the rear brake pedal and no rear brakes. They were pretty good before I removed the right side crank cover. In order to get to the lower bolts of the cover, I took a piece of baling wire and wired the pedal in the down position. I assume, that caused at least, part of the brake problem. I can't see where fluid came out but, I did have to add more fluid. Added the fluid but still no resistance to pedal. Should I try to bleed the rear brakes? Thanks
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
    • By p5200
      This trx300ex was smoking at start up but, then quit after a couple minutes. I was starting every day. I went almost a week without starting and then today I started it and it never smoked a bit. Anyone know what's up here? Has plenty of oil.
  • Similar Tagged Content
  • Gallery Images
