1981 Honda ATC 200 Air/fuel issue
Similar Topics
By p5200
Hello, would something like this work for cleaning jets in a MIKUNI BST40-251 carburetor? If not, suggestions would be appreciated I'm wanting to put an OEM rebuild kit in the original carb and put it back on my 2005 500 Scrambler 4x4 Thanks! 🙂 Tool Shop® Standard Tip Cleaner at Menards®
By Ejwill
Should the clutch plates be so tight together that they can not be moved side to side? There is no play in them at all, will not move at all.
By Ejwill
Can you buy a repair kit for the brush assembly for a gear shift motor for a 2006 Honda rancher 350es? The base plate broke where it is attached by the two screws. Broke right at each screw. All I can find is kits for the starter motor.
By JustinHamilton
Honda 250EX Sportrax. My bike was starting with me kicking the shifter while the neutral light was on. Now it will only click the solenoid. Can I bypass this annoyance?
By Mikael
I recently bought and old Kazuma Dingo 150cc and to begin with it started just fine. Then, for no apparent reason, it wouldn't start. It turns the motor but fuel isn't getting to the spark plug.
As mentioned in the title I've since replaced the fuel filter, the carburetor, the ignition coil and the spark plug. Fuel comes into the carburetor but seems to go no further. Is it a vacuum problem? Does anyone have a good idea about how I could diagnose the problem? And how to fix it?
I don't know what year it's from, sorry.
Sincerely
Mikael
Similar Tagged Content
- 14 replies
- 421 views
- 0 comments
- 546 views
- 0 replies
- 426 views
- 0 replies
- 488 views
- 0 comments
- 1,268 views
Gallery Images
