Quite a project
Similar Topics
By Yammy
Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
Let me know, I'm new to this.
Thanks!
By KansasKodiak
So got my Quad and in a matter of four weeks it's proved a game changer in my hunting prep. I used it to haul all the material to build a suspension bridge across the creek in the back of my property. That creek is a ankle deep trickle mostly except when it rains and then its up to my waist or higher. Kinda limits access during rain. Secondly iI hauled all my stands, climbing sticks and equipment out using the quad. So nice to have the mechanical muscle now.
By kxpro8012345
Hi All,
I have a 1992 Suzuki King Quad 300. I got it in rough, picked apart condition on Facebook marketplace. The previous owner was not mechanically inclined and threw parts, and deleted parts to get this to "run". To give you an idea of what I am dealing with he put a non vacuum carb on with a separate fuel bladder mounted on the rear rack. I live in CT and things are a bit high here so I got the atv with a plow for $400. The atv came with (3) Carbs, 1 OEM, (2) petcocks 1 OEM. What I have done / found is the neutral safety switch was ate by mice (probably the original problem), fixed that, reinstalled (cleaned and put in a new needle and seat) OEM carb, the diaphragm is a little clapped out but still flexible, installed new Fuel pump, cleaned and reinstalled OEM petcock (non vacuum) has slight drip every now and again as I did not replace the tank side gasket when I installed and installed a brand new battery. doing all that the quad fires and runs but briefly. On the handle bar the choke paddle is broke off, I ordered that and looks like you need to remove the grip to install so haven't done yet and If i can get some direction on that as well, So that is "floating" in the carb as I do not have the correct choke cable connector, I took the one off the Chinese carb and it somewhat holds it in place. The air box and system are gone and it has a stubby K&N cone filter on it currently. So the way I start it is pop off the air filer, hold my hand over the carb to get a good enough vacuum to get to the bowl, then it will run for a few seconds. The tank is filled to the top, to help it out. Does anyone think I am missing anything before purchasing the entire air box system (If I can find it). This will be a yard machine for work and will not be taken out recreationally, cool little machine I would like to keep it, but unsure if I will spend the money on a airbox system as it for sure seems I am not pulling a good enough vacuum with out it.
By Valkman
Hey all, new to the forum. I just bought a 2001 King Quad, and the clutch is slipping. I adjusted the play with no improvement, so before I go through the trouble of replacing the clutch disc, I want to see if motor oil in it is the problem. My question is Rotella T4 ok to use? I run in my motorcycles with no issues but I thought I'd get your input.
By Jim Denton
I was gifted four King Quad 300's, they were used to tow portable snow guns around the slopes. All of the plastics are trashed and racks bent up from rolling down the mountain. The lone Quadrunner is a 98, and will be the initial point of focus, as it reportedly ran before being parked in the field of lost dreams.
Similar Tagged Content
- 0 replies
- 763 views
- 6 replies
- 2,182 views
- 7 replies
- 2,056 views
- 4 replies
- 4,142 views
- 10 replies
- 2,193 views
Gallery Images
0
8By iball511,
7
1
4
3
4By mannyortiz7,
3
1
7
6
2
3By dirtqueen,
1
3
1
3By Brand22b,
5By jpjones789,
3By mannyortiz7,
3By Ai-noval,
