By BruinBeater
Hey all, BruinBeater here. Just joined up from the Pittsburgh, PA area.
I'm the unofficial mechanic of the extended family. In the past month or so I've replaced a transmission in a Chevy Silverado, rust repair on a Chevy Malibu, electrical repair on a Subaru Crosstrek, overheating issue solved on a Can Am Commander, and right now I have a pair of Grizzly and a Bruin 350 in the garage. Both have a no start condition and have been sitting for 2+ years.
By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By trootncsse
another new guy. have a Yamaha Kodiak 700 and Polaris 500HO. My brother has a couple of Polaris. Summer in northern Michigan and ride some in Michigans UP where we have a cabin in backwoods. New to quads last year as far as owning one. Have been a jeeper for many years and modified/built several so have some mechanical ability, pretty knowledgable electrically too. Initially started reading the forums to find out what others using for lubes and common issues, other maintenance etc. Hopefully I can contribute.
By Myrtsbnye
Hello All,
I have a 1996 Arctic Cat Bearcat 454 and am in a bit of a quandry. I had a bunch of work done on it over the past couple years...new carb, rear brakes, rear axle and bearings. When the rear axle was replaced the shop noticed the left rear hub was stripped. Problem is, the part (1502-178) is no longer available. I've checked junkyards, ebay and other online parts sites across North America and nothing available. Hate to park the bike after all this work just because of a simple hub.
I have two questions...the front hub (part number 1502-177) how much different would it be from the rear hub? This part is readily available. Would the axles be different diameters?
If these are two different parts and we can't make them work, is it possible to take the existing stripped hub and just weld it to the axle? I know it may sound drastic but was wondering if it would not be too crazy?
Thanks for your time
