Feasibility is one thing, the practicability  of doing it on a motorbike or quad is another thing.
Yes we can supercharge or turbocharge small engines. Whether we should or not bother doing it to a bike or quad is the real question..  I think it's a foolishness..
I know that forced air injection does wear out engines faster, but may be an interesting project to see if it really adds that much more power. Is there a kit for that or are you just going to adapt or make parts from other applications.
  • 6 months later...
    • By Indiana-George
      Anybody know what Arctic Cat airbox components are compatible with Suzuki?
    • By afa913
      Do the small 50cc's have a way to set the speed. Im wanting to get one for my kid and i need to set it to go slow. I know the chinese knock off fourwheelers do but i dont really want one of those
    • By Sonders
      Hey all, I recently bought an 01' Sportsman 500 HO from my brother in-law that he's had since new.  It runs awesome, just has 2 slight issues that I am addressing.  1st issue is fuel dripping out of overflow.  I did some searching around and saw that the O-rings in the carb wear out and allow fuel to leak, so I replaced both the Orings inside the carb.  This didn't fix it and still leaking which leads me to believe the float needs adjusted, I'm just not sure on correct way to check and correct this.  2nd issue is no speedometer.  Also in researching this it appears to be Hall Effect/speed sensor.  I'll be ordering one of those to replace, which sounds like a pretty straight forward process.  I guess really my only reason for the post is to get some help on the gas leak issue.  Any thoughts?  Other than that, I love the bike and really enjoy riding it.  Thanks in advance for any replies.
    • By Scott M
      Hi all. I've had a 1994 350 Warrior for 15 years or so, love it but, I'm wanting it to be a 4x4. With my limited knowledge I've come up with maybe a 2005ish wolverine 450 4x4.  I really need advise on what to look for though!
      I'm liking the prices on the early 2000s. The biggest concern is it fitting it my truck. I have a 2016 Colorado crew cab (5 foot bed). I'm not worried about length at all just width of the front wheels I think I guess...
      I think I heard that the Kodiak is the same as the Wolverine but it has a front locker??? I'm not overlooking other brands, I just searched around and came up with these.
      What do you guys think? What would you get for under about $5 grand, 4x4, that is relatively light weight and will fit in my pickup?
      news Equipping your ATV or UTV mechanic the right way
      Someday you might just have to work on your own machine and having these tools could make it easier. View the full article
