Guest Goatman
I have a 05 400 cat and did not notice that I had torn a boot untill it was to late. The outer joint is shot. How do the axles come out? Is it a c-clip that has to be removed first or is it a pin type that can be removed with a slide hammer. Love the site. Any help would be greatly appreciated!
If you change one joint , change both on the same shaft. I have done this when helping friends change them out. On a car or truck It I change the entire shaft. Also I would change both because my luck would be to tear it apart 2 days later to change the other joint.
Guest Goatman
I priced out the shaft online and it looks like for about $200 I can get the entire " Half-Shaft" is what the part is called. Can I assume that this part is both joints and the shaft? Thanks Buck. Is the truck in the picture yours? I also have a 1978 Chev full-size with a 400 horse small block 400 and a 9" lift, lots a fun. I'm not sure why but if I can't get it stuck, I don't think I am trying hard enough!
  • 5 months later...
    • By Frank Angerano
    • By Heymax
      I bought a 2003 Bombardier Quest XT 650
    • By Mcsful8er
      Just picked up a 95 Polaris trailblazer 250, needs a little work but he’s pretty stoked
