Nick's 450r starts better than mine does for sure. He gets his started and just walks away while i'm standing there with my throttle open for a min. or two till she gets warm....
But in the summer, its different....doesn't take that much to start her. Have you tried using the choke?? I dont remember you talkin about that...
Mine runs like Nick's. I fire it up and ignore it. I can hear in how it revs when I need to turn the choke off. If I can get it fired up in the cold, I'm golden.
I don't think Nick ever uses his choke. I have to, on occassion...but I hardly ever do because I actually have my choke zip tied closed...it tends to vibrate on during races for some reason...but that's besides the point.
TB, did the guy give you a history lesson on the quad?
I'm also up at 8000+ feet. That has a lot to do with it. When I go to the low lands and ride around 5000 I don't.
I have built a snow plow and a yard trailer out of scap steel from work.
Do u have pictures on the plow.. or any info on the steel u used and how u built the mount.
I used box tubing for the frame work. I had tabs on the frame. But all you need is a piece of flat steel to mount to the bottom of the frame. make a pivot point there. Run the box tubing from there to the plow. Buy a used garden tractor blade. Look how blades are mounted from the dealer to get ideas. I modified mine 4 times before I was happy. I'll try to get some pictures later. I'll start a new thread later.
im still waiting on the nerfss and stuff. but my dad cracked it open to take a look at things, cam chain is loose. ive heard around about a 2002 CRF450 cam chain working, and found one for 10$. might spring for it, and we bought plugs, but havent got the right socket to fit yet.. i think we will have to wait untill monday when my local dealer is open. i cleaned it up though and here are some pics of it. with NOTHING DONE TO IT.
sorry for the lack of excitement going on in this project...but its going a lot faster than the TB did! i have money this time lol
Edited by trailblazer_02
heyyy people...long time no speak.
progress: painted the heat shield...ordered the cam chain last night, its on express shipping. took off the header, sanded it, and everything, paiting it with heat paint. will also paint the muffler.
tommorow, or today for most of you since its so late, i will do the rest of the sanding, prob start the painting on the header..just a question..since its cold. will that have any effect on the paint drying? what if i put a heater near it? ill do a coat or two of clear on the heat shield..uhhm..prob start tearing more of the 400 down and taking parts off for paint..prob doing some sanding on those items...prob try flipping the rims and see if it makes it any wider, have to measure the bars for a new bar pad..thats about it for tommorow.
ill keep you guys updated.
heres my heat shield i prepped and painted myself.
hey ppl. long time..well not many updates on this..
lets see where im at..
im about to send the clutch cover, throttle cover, master cylinder cover, and heat shield off for powder coating in candy red.
got the HD cam chain. have yet to put it on,
got some extra tires from someone, stock 20's.
seat cover should be bought soon.
and a hood. [maybe]
o yeah and i finally got it to start..it was the plug.
header still isnt painted, but it should be done soon.
hey people... i always drift away from this place for some reason. i do not know why...i love this place, do not know why i stay away. anyway. updates on the project...it is done lol
go it all together, and i bought ANOTHER quad. i got a little 300ex from a guy for 600 bucks. it is a little rough but it runs and rides!!
anyway here is a before and after...and there are more plans for this come winter.
BEFORE: 13yjyhk.jpg
AFTER: 1zpqvir.jpgrsc3md.jpgsy4k89.jpg
    • By newguy024
    • By NZrider
    • By jatho
