VOTE FOR QUADCRAZY-Top 100 ORV Sites
By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By dlgg7
I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ??? -
By Robin442
Hello all! New to the site, I came here seeking answers as I've decided to help my cousin get his once good running buyou 220 going again.
I've owned an 82 kawasaki kz1100 and have done lots of work to it over 20 years of ownership.
Looks like the wire diagram colors are same or similar to my bikes wiring, a definite plus
Cousin was riding through fairly high weeds and brush after it's rained, when it just died. It would turn over but no fire.
This to me sounds like perhaps a CDI issue or a fried coil, idk that why I'm asking you gurus LOL
Similar Tagged Forum Content
- 1 reply
- 2,040 views
- 30 replies
- 25,119 views
- 1 reply
- 4,026 views
- 5 replies
- 6,705 views
- 2 replies
- 1,706 views
