So i got a used raptor 660 was running fine then parked it for an hour or so then it started having some problems. It starts and idels fine then when you give it some gas it bogs out and bacfires. So i just went through it changed the gas, oil, and hit it with some carb cleaner and its still bogging out at higher rpms. have ridden it about an hour or so to make sure things were cleaned out, still doing it, and seems to be running very hot. help?
is their any mods done to it such as different air-filter or exhaust? tack ur plug out an tell me what the color of it is.. if it spudders at a high rpm their could be something wrong with ur carb such as a wrong jet size thats always my first guess wen problems like this occur
for mods it has a yoshi pipe and a jet kit. spark plug is new, i took apart one of the carbs today and it looks very clean, wasent able to get into the other becuase of a stripped screw. im thinking it might have to be re-jetted because of the change in weather
    • By Gtc4d
      Thanks.
      Todd
    • By BillR94
      Thank you for your time
      Bill
    • By Jason39
    • By jordan_ATV
    • By austinfuller22
      i have a lt 230 and the e start isnt working but i dont know why
      can i have some help
