How do I and where is the idle screw adjustment for a boys' Raptor 80? After it warms up and sometimes when it is cold, it will not idle very well, mostly when it warms up though. I have looked for the adjustment and cannot find it. I must be blind. It has approximately 15 hrs on it since new in April 2006. Anyway, please help me.
Steve
The fuel screw should be in the same place as on your other Raptor, just in front of the floatbowl, on the bottom of the carb. That might help. After it warms up, will it idle with the choke on? If so, you could have an air leak.
Hey thanks I will take a look and see if I can adjust it. It will idle on partial choke but not full choke. Full choke will make it die, even the partial choke tries to make it die if you run it for too long.
Thanks for the help, I do appreciate it.
Steve
I stand corrected, looking at the diagram that AJMboy provided, the the idle and pilot screws are both located on the side of the carb, the pilot circuit adjustment is probably the one behind the blind plug.
    • By Gtc4d
      Thanks.
      Todd
    • By jordan_ATV
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
