newb
Welcome, that is a nice ride you got there. I am curious where you got an '05 250R since the last year they were produced was 1989. Is it a fresh build using after an aftermarkets frame and other newer parts? Or maybe a 450R or 400EX with a 250R motor and plastics? Can you post some better pics of that thing?
My bad thare dirt demon it is an 87 trx250r that was restored from the ground up will post some better pics of the trx250r
nice ride and welcome to the site :) i hear a lot of parts are interchangeable between the 250 and 400...
I have +2 Burgard a-arms for a 400EX on my R, you just have to use spacers on the '86 and '87 frames, I believe they are a direct bolt-on for the '88 and '89's. I use the 400EX spindles, hubs and brakes too, but I am working on adapters to put the R brakes on the EX spindles because the R has twin piston calipers and the 400EX brakes just don't cut it with the CR 500 motor.
Eduardo, that is one clean R, that thing is immaculate.
    • By Spritee1
      not sure where to look next
    • By newguy024
    • By hardcastle
    • By McG75
