By OldATVowner
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By BillR94
By BuckBilly
Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
