My new KQ just suddenly started backfiring VERY loudly sometimes when I get out of the throttle at a good speed and let the motor help me to slow down along with braking. It also will make a soft backfire if I rev it up a little in neutral, and the last symptom it has is when I get it up to temp and let it idle it will purr like a kitten and all of a sudden just shut off intermittently. I already bought a new plug, gapped it, installed it and if anything it made it worse. I did have the 100 mile service done not long ago and it just turned 400 miles today so it leads me to believe that it may be running just a little lean but I wanted to run by everyone here to see if anyone else has had this happen and if so, how you remedied it.
I'm assuming this has a carb and not Fuel Injected like it's big brother...
Sounds like it's running out of fuel in the carb bowl. Has this quad sat for a little bit or have you been pretty regular riding it. It's a 2008 and they're almost at 2010 models....so it's 2 years old. Maybe the carb needs a cleaning?
I guess I should have mentioned that it has a carb but no, it hasn't sat very much at all. I just purchased it a couple months ago and ride it regularly either at the house or at our hunting lease a couple days a week. Wish I could find a clymer manual for it so I would feel comfortable removing the carb bowl to check for trash. Anybody have any links or pics on removal of a Keihin CVK32 carb?
It is possable that the fuel pump vacume line has a leak. If this happens, the fuel pump doesn't work well and air is introduced making the engine run lean. Assuming of corse that this machine has a fuel pump . Also if it has a vacume fuel petcock, check that vacume line as well.
    • By Elk
      2002 Polaris Magnum 325
    • By OldATVowner
    • By wilmpie
      hi everybody
      I have a kymco mxu 250 automatic from 2006 250 cc  that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
      if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
      what can it be or what can i do to fix this?
      thanx in advance
      p.s. Sorry for my bad english it's not my first language.
    • By BillR94
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
