what's up everybody!!!- onequikkaw
By DemonQuad666
I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
By gatorschevy
I also have a magnum 4x4 that I am working on it is getting a new piston, In the tear down I pulled off the flywheel
and found that all the magnets are not attached? why does this happen? there all in good shape so is it possible
to reattach them to the flywheel? I can buy a different flywheel, but it looks like around $300 or more and one of them on Ebay
looks like the spacing is off a little so it may have the same issue.
the stator looks good also
By dbconn55
Hi guys I have a 2003 Arctic 250 4X4 it starts idles and runs great for about 10 min. then it spits and sputters and dies but it starts right up like nothing happened idles good till you give gas and it does it again let off the gas and it's idling great again this goes on for about 15 to 20 min. and then it takes off runs good all day like nothing was wrong.
I cleaned the carburetor it looked like a new one inside found a little gunk in one orifice, new air filter no crimped lines air line to tank good I did put a meter on the battery idling it said 16.5 V that's high I think would a voltage regulator cause this?
Suzuki shop wanted to sale me a stator for $556.00 but said it could be something else also thought I'd see what you guys say about it
