By OldATVowner
By tflack500tbx
Background,
Any Ideas?
By jeffrocdx
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
what can it be or what can i do to fix this?
thanx in advance
p.s. Sorry for my bad english it's not my first language.
By BillR94
Thank you for your time
Bill
