I have a 2009 Kawasaki brute force 650i that I bought from a salvage dealer. When it was bought it had 98 miles on it. Everything that was broke was fixed including a new crank and piston rings (the motor was apart). However one problem remains it will shift in all gears but will not engage in all gears. The shift linkage can be adjusted so that it shift to all gears but low does not engage or it can be adjusted so that it shifts to all gears but reverse is not engaged. I just can't get both low and reverse to engage with any adjustment. Also the only indicator light that ever comes on is the neutral. I have been told that the shaft might be bent or the bracket on the end. They both look good to me. Any suggestions.
Sorry for the late response, I did not see this post until now, it must have been moved in from somewhere else.
If a bracket was bent, or something was reassembled incorrectly, that could cause the problems you are having. I would look to see if there are any parts in the linkage that could possibly be put on differently, possibly a bracket that needs to be turned around. Maybe there is a bracket that could be bent a little and you can't tell because you have only seen it the way it is now. You might try bending something to help gain some more adjustment.
I will be adding the year make and model to this thread title.
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By marlon smith
    • By cruteg8
      Does anyone know forsure if u can swap out the Crank Case on a 2001 kawasaki Lakota 300 sport  with a kawasaki Bayou 300 Im seeing yes and no all over some say the mounting position is different so you can't swap the cases but everyother inernal engine part you can swap then im seeing no problem bolts right on can someone plz clarify who knows forsure
    • By sunn
      Maybe someone has the answer to correct a long cranking but did start after maybe 10 seconds?
      Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted.  The atv started, but then died a couple times after repeated attempts.  But when run awhile everything was ok.  Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
      Is this typical of a failing fuel pump?
      I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM.  Just had all covers off so looks really easy to replace.
      Any ideas?
