If you every need any help with the 90 sportsman let me know we raced with that same motor in a Kasea 90 (took the championship). We've done just about everything with that motor application.
Polaris and Honda are both good for their own uses and both have pros and cons. We own both and opinions vary thats why we don't bash someone else's ride. It's all good!!!!!!!!! We need to hang together for our sport!!!!
  • 12 years later...
I am going through an issue with a predator 90. I replaced belt rollers and clutch and drum. It has no power like the belt is slipping or something. I don't know. I put the old one on same thing. Is there something I am missing?
    • By Coyote251
    • By Sportsman500guy
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
    • By Ejwill
    • By waybel
      Picked up this old 2000 polaris sportsman 500 and the speedometer is dead .Tried the bypass to get the awd drive to work but no luck.I grounded the 2 brown wires going to the hubs .Didn't work.The AWD light does not come on and there is no power on the grey wires going to the hubs .I even tried connecting the 2 brown wires at the speedometer plug in .There is 12 volts on the red with white stripe connected to brown at the speedometer plug in .Does the speedometer need to be plugged back in for this to work.Could it be the switch or a burned AWD bulb ?
