MY 98 xployer start good, runs good for about 15 min. then starts missing and shuts off and wont start till it cools off. Any idea what it could be?
Sounds like an ignition issue, likely the CDI, stator or pickup. You need to determine what is missing from the equation when the machine stops running. After it dies check for spark, if you have none, then you know to look toward the ignition system.
Edited by DirtDemon
    • By Tinkeringreg
    • By kaidella
    • By Mmessy83
      I recently purchased a complete lt230s for$50. It was missing the kick starter gears which I got off eBay for $18. I’m trying to install the gears which after reading different threads about having it timed. I have it all timed but now it acts like engine is seized up but I know it’s not. What could be going on??? Any insight would greatly be appreciated.
    • By TimothyLindblom
      Timothy
