Similar Topics
By dlgg7
I've had this for probably 15 years. It ran great till 4-5 years ago, mainly riding the grandkids around our fields, till it wouldn't start. It sat for a couple of years till I bought a new battery, but couldn't get it to even hit, so rebuilt the carb, put on a new fuel pump, but no go, so it's sat. Several days ago, charged battery, cranked over and it started??? OK, idles good, but won't rev up, so emptied gas tank, flushed out and filled w/good 93 octane, pulled pump line from carb and have good full line of fuel cranking over. New spark plug, good spark, old one black BAD! Oil change, adjusted valves, no difference. Pulled carb and took apart and cleaned, didn't find any clogs or crusted up inside. Now I've had the carb back off probably 6 times checking, double checking anything I can think of. No gas blowing back in air box. It idles good, can increase throttle up some then starts popping and dropping rpms off and if I don't let off the throttle, it'll die. I've read for 3 days now MECHs and RANDY walking several thru tracing the same problem, tried MOST of the direction given. ??? -
By jscarter32
Greetings all, The bug has gotten me and just bought a 2002 non-running Yamaha Kodiak 400. Hoping to find info here to get her running again!
By Cheetah
Hello,
recently I removed my starter because it was to slow so before buying a new one I thought cleaning it. So I did and it did went much better.
The thing is I replaced it exactly as it was but since then the starter goes freely like there’s no dentelywheels.
Did I do something wrong ?
Similar Tagged Content
- 2 replies
- 3,204 views
- 3 replies
- 4,078 views
- 0 replies
- 4,255 views
- 1 reply
- 3,799 views
- 0 replies
- 2,209 views
Gallery Images
By George Henry,
By CK1999_400ex,
By nyatvrida91,
By mannyortiz7,
By dirtmerchant42,
By mannyortiz7,
By blahhhh,
By mannyortiz7,
By SeanKing,
