hi i have a 06 700 kingquad and i wondering if anyone can help me the bike is missing if you take off to fast and once your up to 80 or so and hit the throttle it will stall the exhaust is also getting red from the head back to the muffler tip i have changed the battery took the tank off and cleans the pump cheaked for broken wires and cant find anything also it runs around 13 volts with no lights on but when there on it will drop all the way down to 8-9 could the be the statior or regulator and has anyone ever had the throttle posion going bad i wonder if that is causing the miss in the injuctor but if anyone has any of these problem i would like to know if there is a easy fix befor i start buying parts thanks
Edited by littlemac
That quad should be fuel injected. Have you checked your air filter for clogging. At high rev, you need allot of airflow.
* Changed your thread title, included year, make, and issue.
I am inclined to agree with Ajmboy, it sounds like you aren't burning enough of the fuel in the combustion cycle, so it burns off in the exhuast making it get hot like that. A clogged air cleaner seems like the most likely thing to me as well. It would explain the stumbling in performance too. Check the air cleaner first, but if that is not the problem, I would check the throttle position sensor next. Also, there may be a sensor inside your air box, it is an air temp. sensor, that could be causing problems too. There is also an air pressure sensor on the throttle body, if that isn't reading properly, it will affect fuel delivery. I assume that the engine temp. light is not coming on, right?
Edited by DirtDemon
