Similar Topics
By gohndd
Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
By jscarter32
Greetings all, The bug has gotten me and just bought a 2002 non-running Yamaha Kodiak 400. Hoping to find info here to get her running again!
By DrtyGrlKristin
By glencam
Hi everyone new to this forum so thanks for taking the time to read my questions. I have an older 88 Big Bear 350 and it wont go into Hi range ....well I think its Hi it wont go into it may not go into low range it will go into reverse when i shift the shifter it moves all the way back (i removed the pin and manually shifted it ) forward is reverse middle is low and all the way back is hi but when in hi position its like its in N no forward movement of the machine in any gear. I did get it to work once but then shifted to reverse to get it out of garage and the problem returned.
Where is the Hi/Lo gears actually situated? by removing the right side cover to expose the clutch will I gain access to the shifter?
The "Middle Gear" housing on the other side (left) does it take gear oil ?
thank you
Similar Tagged Content
- 7 replies
- 4,121 views
- 5 replies
- 6,760 views
- 1 reply
- 4,300 views
- 0 replies
- 3,036 views
- 1 reply
- 3,564 views
Gallery Images
