I have to disagree I beleve the stock bolt pattern front and rear is a 4/115 the front offset being 5+1.5 and the rear offset being 5+2 I hope this helps if you are looking for new wheels I would recommend Rocky Mountain atv I just got some there for my Kawasaki Teryx for a sweet deal.
  • 3 months later...
    • By noticon75
    • By tepin
    • By Shorty51
    • By toe420
