Hi I was wondering if I could replace my 2007 500's LCD Display with a 2007 700's display, would there be any problems, would it fit, my 500's LCD display is not working properly only a 1/4 of it is working. I would greatly appreciate any help you can give thinks or any good alternatives
Good question. What I woudl do is call the dealer and see if the connections are the same and teh unit is the same part #.
* Added year, make, and model to your thread title.
    • By Jason39
    • By Asand211
    • By austinfuller22
      i have a lt 230 and the e start isnt working but i dont know why
      can i have some help
    • By TravisCr
    • By Tim Keiper
