Guest woodsman1st
I bought this 98 Suzuki knowing that the front differential was bad, and the rear one might be. But I am on Social Security without much money, I am disabled, can't hardly walk, and the only way I can keep on hunting and fishing is if I get this running; this is what I can afford.
I followed the instructions in my Clymer repair manual; so far everything is dismantled and the right front axle is out; it came out just like the book said it would with a "light tap". But I can't get the left front axle out no matter what I do. It is supposed to come out as easy as the right one, with just a light tap or two; but I have tapped and banged as hard as I dare to without breaking something; I just cant get that left front axle out; what am I doing wrong?
Is there some kind of circlip, or retainer, on the left axle inside the differential that holds it in? I cannot find anything in the Clymer manual that says there is; but that axle just will not budge; and as I said a little tap isnt doing it; and I am afraid to bang on it any harder. I can't affor to take it to a shop; not only that but the front end is all apart and I couldnt get it into my pickup bed even if I wanted to now.
So will somebody please help me and tell me what I am doing wrong; I really need to get this running so I can keep on fishing and hunting.
Ken
yes there is a circlip holding the cv into the cup...the outer cv joint comes off the axle by holding the axle in a vise and tapping the race. the inboard half will only come out if you pull the cv boot back, wipe the grase out and get a small screwdriver, find the clip which if i remember correctly just looks like a large hoop earing thing and is set back in the cup about a quarter inch...
check out this page here, lots of great info, i got my half shafts for my lt500 4x4 from them, theyre awesome, dealer wanted 400 for a new axle, i got 2 outer cv joints, heavy duty with heavy duty boots and cv grease for 80 bucks each !!!
CV Restoration LLC. Selling high quality parts, at wholesale prices!
Guest woodsman1st
Thank you very much superswire; I have been going nuts trying to figure this out. I have doube and triple checked my Clymer manual and no reference is made to a circlip. I am going to save your email in my Suzuki folder; because when I clicked on your link for more info, it said the page didn't exist. Any chance of your double checking that link for me?
It is 8:00 in the morning here in Idaho; I will be out working on it again within the hour thanks to you.
Best Regards
Ken
  • 5 months later...
    • By jay41198
    • By bradleyheathhays
      Unfortunately it looks like I have some people in my new neighborhood paying a little too much attention to my auto and for the first time I'm feeling a need to add some security system(s) to old yeller.  I think just a basic remote arm system would do, not interested at all in remote start or unlock.  I'm not familiar with modern alarm systems, but here's what I 'think' I need...
      - Door switches for all 5 doors (rear hatch).  Probably a PITA to install but that's only an initial idea.
      - 'Bump' alarm (not sure what it would be called) for if a window breaks or if something is jarred
      - Geo-location function like a low track or something similar
      Additionally I'd like to install possibly 2 start kill switches.  I'm not sure where inline these are normally installed but my impression is that directly in line with the key ignition switch would be common.  But then what if someone jumps the starter with a screwdriver...would this type of switch work in that instance?  So that leads me to the idea of a second ignition kill switch which would either be wired between the battery and starter motor, or between the starter motor and ground.
      And last...security lugs.
      So am I over thinking this here?  What's your recommendation for what I really need and maybe a good but economic alarm system that can get this done?
    • By LMI
    • By kevinohio
    • By buriedpast
